383 ??? - Team Camaro Tech
post #1 of 2 (permalink) Old Sep 30th, 05, 07:58 AM Thread Starter
383 ???
I have just got my 68 running and it has a 327-275 hp in it that has had some mods done to it but it is just not getting it.I have a 010 72 modle 350 4-blt main short block that seems like it is a standard bore,it spins easy and seems solid, I just haven't taken it to a machine shop to have it checked.What I was wandering is what process that you have to go through to build a 383 from a 350 block ,could someone brake it down for me,plus I also have a 509 010-020 400 73 model standard bore block.Any help would be appreciated Thanks Camaro BOB
bdcole_51 is offline
post #2 of 2 (permalink) Old Sep 30th, 05, 08:31 AM
Lightbulb Re: 383 ???
A 383 is built using a 400 crankshaft machined to a 350 main bearing size. it is likely cheaper to purchase a eagle or scat rotating assembly than to use the production crank. A 400 ballancer and flexplate must be used aswell. You can use a stock 400 rod ( NOT RECOMEDNED ), stock 350 rod (5.700"), or a long rod of 6.00". It's not that you are limited to 383 either, we have built up to 396 cube in stock 350 blocks. With the 400 block you can stroke it safely to a 421.
427ls1 is offline
327 or 383?.......rpm or torque? makoshark Performance 25 Jun 4th, 06 02:18 PM
383 build-which cam tumper Performance 20 Aug 31st, 05 07:44 PM
HEI problems - 383 popping update/help 67RS502 Performance 9 Jul 29th, 05 05:10 AM
357 to 383 - Strange Change in Exhaust Sound Fuji Performance 14 May 11th, 04 05:38 AM
350 vs. 383 travis Performance 5 Aug 1st, 02 03:29 PM
