Need help with stock fuel pump to AN fittings - Team Camaro Tech
post #1 of 12 (permalink) Old Sep 30th, 05, 07:47 PM Thread Starter
Dan
I'm looking to attach new fuel line with AN fittings to a stock fuel pump that currently has a 3/8" line so I can plumb a new line from carb to pump with braided hose. The stock pump has a 5/8" female inverted flare fitting, as far as I can tell. Is there an adaptor that will readily fit into the pump to convert it to an AN type? I see a fitting on Summit's site that is a 5/8" male to -6 AN (EAR-991947ERL), but I don't know if the flare angles are compatible since I've encountered 42 degree and 45 degree angles. What would you suggest?
DanW is offline
post #2 of 12 (permalink) Old Sep 30th, 05, 09:06 PM
J.J.
Send a message via AIM to jj69z28
Re: Need help with stock fuel pump to AN fittings
check out http://www.russellperformance.com/ under adapters.
Rally Green 1969 Camaro Z/28
jj69z28 is offline
post #3 of 12 (permalink) Old Oct 1st, 05, 06:59 PM Thread Starter
Dan
Looked in Russell, but don't see the part I'm talking about for the application.
Has anyone had experience with using either
Earl's 991947ERL;
Summit's SUM-220667; or
Aeroquip's FBM2964
-6 AN Male to 5/ 8-18 in. inverted flare fitting to successfully convert the stock fuel pump 3/8" pipe outlet fitting to -6 AN?
I'd like to reuse the stock pump and I am gathering a parts list.
DanW is offline
post #4 of 12 (permalink) Old Oct 1st, 05, 08:41 PM
I seem to recall when I plumbed mine that it was absolutely impossible for some reason... ended up buying a Holley pump to get a pipe thread I could screw an adapter into.
post #5 of 12 (permalink) Old Oct 1st, 05, 09:09 PM Thread Starter
Dan
Jim,
While I was searching on this topic I read that thread where you were trying to plumb the line between pump and carb:
https://www.camaros.net/forums/showthread.php?t=37892
I was hoping to avoid the same frustration! From what I think I have found it is possible to adapt the stock outlet to AN -6 with one fitting. On page seven of Earl's online manual they have a fitting for 3/8 inverted flare fittings.
http://www.earls.co.uk/car/3_hose_fi...m_adapters.pdf
I was hoping to find someone that has achieved success with using it before I ordered a whole bunch of fittings only to find out I need something else.
DanW is offline
post #6 of 12 (permalink) Old Oct 1st, 05, 09:31 PM
I remeber that post... it worked out in the end, and i like the big chrome fuel pump just fine. good luck finding that fitting!
post #7 of 12 (permalink) Old Oct 1st, 05, 10:25 PM
Jody
camcojb's Avatar
You can definitely do it with one fitting, you just need to verify the thread on the pump. 3/8" fuel line is NOT 3/8" inverted flare, it's probably 5/8" inverted thread. Find the fine thread bolt that fits in the pump and you'll know the inverted thread size. The inverted threads are sized like bolt threads, not pipe threads or tubing size.
Jody
camcojb is offline
post #8 of 12 (permalink) Old Oct 1st, 05, 11:22 PM
ZZ_430's Avatar
Thumbs up Re: Need help with stock fuel pump to AN fittings
Jody
http://store.summitracing.com/partde...=KeywordSearch
Don ~ TC Member #15 ~
Don't mess with Texas!
ZZ_430 is offline
post #9 of 12 (permalink) Old Oct 2nd, 05, 12:24 AM Thread Starter
Dan
I know the threads on the pump fitting are 5/8-18 UNF and the fuel line is 3/8" 45 degree double-flared tube. When I was referring to the inverted flare, I was describing the joining cone on the existing fuel pump fitting that the flared tube seals against.
DanW is offline
post #10 of 12 (permalink) Old Oct 2nd, 05, 09:05 AM
Jody
camcojb's Avatar
The 991947ERL should be the correct fitting.
Jody
camcojb is offline
post #11 of 12 (permalink) Old Oct 2nd, 05, 10:18 AM
Jody
That would be the detail I didn't know when I did mine.
post #12 of 12 (permalink) Old Oct 2nd, 05, 11:03 AM Thread Starter
Dan
Thanks for the confirmation
DanW is offline
Original AC fuel pump bilodeaulynn Restoration Corner 7 Jun 6th, 05 10:39 PM
Second gen fuel pump on first gen CurtiSS 69 Engine 1 Mar 1st, 05 07:02 AM
Which electric fuel pump? paul1969 Performance 6 Mar 22nd, 03 03:28 PM
new fuel pump -- stalling out robbZ28 Troubleshooting 6 Sep 4th, 01 08:29 PM
fuel pump question? hi-po327 Tech 2000 2 Jan 6th, 01 05:47 PM
