366 motor - Team Camaro Tech
post #1 of 4 (permalink) Old Sep 30th, 05, 08:13 PM Thread Starter
Lightbulb 366 motor
does anybody know anything about a 366 big block motor for a camaro,i heard it has a lot of torque,also hearld it good w/ a high rear gears like 3:08s
anybody have any input thanks
jdbr1 is offline
post #2 of 4 (permalink) Old Sep 30th, 05, 08:26 PM
Chad
67 Plum's Avatar
Re: 366 motor
366 is a truck engine 2 ton and up.They make torque down low 1500 to 3000 rpms.I rode in a 68 convert. with one in it once it was a pig.A 283 would have blistered it.If you can find a 454 block you can use the crank and rods to build a 427.The crank and rods are the same as a 396 or 402.
67 Plum is offline
post #3 of 4 (permalink) Old Oct 1st, 05, 08:27 AM
Re: 366 motor
Take the crank and rods, pitch the rest.
mls48341 is offline
post #4 of 4 (permalink) Old Oct 1st, 05, 03:27 PM
Smile Re: 366 motor
Save the heads b/c even if they have 1.84" or 1.94"/1.66" valves in them, you SHOULD be able to cut them out and install regular sized valves in them fine b/c the basic ports are the same size!
Just the seats weren't cut for bigger valves is all..
UNLESS they are peanut port, -236 heads that have intake ports that are wider than they are tall! Start with better heads to begin with then...
(Peanut Ports are like 200 cc's or so up to about 230 max.)....
pdq67
motor not running smooth... fixed camaro man Engine 1 Sep 16th, 05 07:56 PM
motor not running smooth... fixed camaro man Engine 0 Sep 16th, 05 07:51 PM
Siezed motor Pono Engine 3 May 18th, 04 09:18 AM
Any way to tell if vibration is coming from motor mounts of balancer? denverRS/SS Engine 6 Nov 6th, 02 02:28 PM
new motor, mounts...shakes like crazy jks67SS396 Performance 8 Sep 13th, 02 03:41 PM
