Bronze, iron, steel distributor. whats the dif? - Team Camaro Tech
post #1 of 5 (permalink) Old Sep 30th, 05, 10:25 PM Thread Starter
Red face Bronze, iron, steel distributor. whats the dif?
Whats the difference between the different types of material used in the gear and why is it important. I know ive seen this somewhere but for thel life of me I cant remember why.
Long Gone: 1984 Z28, 1989 RS
Current : 1967 Coupe w/350, 2010 2SS
My Photobucket >>
dragon0123 is offline
post #2 of 5 (permalink) Old Oct 1st, 05, 10:17 AM
Re: Bronze, iron, steel distributor. whats the dif?
The softness / hardness of the gear needs to be matched to the cam gear material. The cam manf. documentation should tell you which gear to use. Perhaps someone here can give you specifics.
One common issue is the use of a brass gear with a high pressure oil pump. The oil pump puts such a load on the gear that it wears out very quickly.
dnult is offline
post #3 of 5 (permalink) Old Oct 2nd, 05, 11:08 PM Thread Starter
Well if brass is so soft, why would one want to use it anyway..? why not just use steel for them all.?
My Photobucket >>
post #4 of 5 (permalink) Old Oct 3rd, 05, 12:08 AM
Because certain billet roller cam cores are softer than cast iron flat tappet cores.
If you use a cast iron distributor gear on a "soft" billet roller camshaft, you'll wear out out the cam's drive gear and then you'd have to replace the cam because the cast iron it's so much harder. Obviously, it's much easier to replace the softer, worn distributor gear.
Also, if you use a bronze (not brass) gear on a cast iron cam, you'll destroy it in no time.
..And not all roller cams are billet and require bronze gears. The Crane 138101 roller cam I will be using requires a regular cast iron distributor gear.
BlackoutSteve is offline
post #5 of 5 (permalink) Old Oct 3rd, 05, 07:48 AM
You can use bronze on any cam but it does wear faster. A steel billet roller has to use the bronze gear or the new polymer gear from comp. A cast cam can use any gear but normally uses a cast gear for longevity. If you use the cast gear on the steel billet it wont wear the cam but the distributor gear will be gone in under 50 miles
Racing 68 is offline
which distributor gear to use, steel or bronze ? cottonpicker14 Tech 2003 6 Dec 28th, 03 05:00 PM
Aluminum heads vs. Cast Iron Heads peter19u Performance 67 Jul 15th, 03 03:16 PM
400 SBC COMPRESSION RATIO DTL504 Performance 37 Dec 10th, 02 08:39 PM
The axle housing, is steel or cast iron ? cottonpicker14 Tech 2002 5 May 29th, 02 04:35 PM
