Edelbrock Performer Question - Team Camaro Tech
post #1 of 6 (permalink) Old Oct 1st, 05, 05:08 AM Thread Starter
It's been a while since I've been here. I got real busy with work and family.
Anyways, I'm planning on getting into my carb this winter among other things.
Here's the situation.
The car is a '68 RS Camaro with the original 327(mildly modified), original 2 barrel carb and manifold was removed and 4 barrel manifold and new(er) edelbrock #1405 manual choke carb installed before I bought it.
The problem is that any time I accelerate hard it runs really rich. I can see the gas gage drop after each time. The car is hard to start cold also.
I've bought the calibration kit with the rods, springs etc.,. But before I get into it I thought I'd ask the experts aroung here.
Joe
jogasz28 is offline
post #2 of 6 (permalink) Old Oct 1st, 05, 06:59 AM
Re: Edelbrock Performer Question
That is a normal problem with edelbrock carbs.
Rogers Performance is offline
post #3 of 6 (permalink) Old Oct 1st, 05, 10:51 AM
Dan
You may want to try moving the accelerator pump rod one hole farther from the carb body to shorten the stroke and thus reduce the volume of gas the accelerator pump produces.
DanW is offline
post #4 of 6 (permalink) Old Oct 2nd, 05, 08:31 AM Thread Starter
Thanks Dan.
The pump rod was in the middle hole of 3 holes in the lever. I moved it to the outer hole and will drive it today.
Joe
jogasz28 is offline
post #5 of 6 (permalink) Old Oct 2nd, 05, 10:37 AM
I have a Performer carb on a 355 in my pickup. It has always shot black out the back when I get on it. It also takes a while to start if it sets very long. When I built the 355 for my Camaro I went with the 670 Avenger and have had no problems.
deerhunter is offline
post #6 of 6 (permalink) Old Oct 3rd, 05, 05:01 PM Thread Starter
Took the 68 for a ride. No more loading up at all. No bogging down when I stomped on it either.
When I got back I changed the plugs. The ones I pulled looked to be lean. The grounds were white. I'm thinking someone tried to overcome a lean condition with more accelerator pump.
Joe
jogasz28 is offline
Edelbrock performer rpm heads cradfordchevy1 Performance 8 Mar 27th, 05 03:20 AM
Edelbrock 1400 question 67CamaroD Performance 2 Mar 22nd, 05 01:01 AM
edelbrock 1406 question bmann2 Engine 6 Apr 21st, 03 09:08 AM
Edelbrock air gap Performer RPM hood clearance. no bail4u Performance 3 Aug 2nd, 02 07:28 AM
Edelbrock Cam and Intake Question Mark W. Winning Engine 18 Oct 30th, 00 08:01 AM
