1.75 ratio 6-banger rockers on a SB head. - Team Camaro Tech
post #1 of 9 (permalink) Old Oct 1st, 05, 07:17 PM Thread Starter
Question 1.75 ratio 6-banger rockers on a SB head.
Anybody ever do this for a cheap increase in rocker ratio??
I know the 1.7 ratio BB rocker install is spelled out in Chevy Power but not the 6-banger rockers..
pdq67
post #2 of 9 (permalink) Old Oct 2nd, 05, 11:17 AM Thread Starter
Smile Re: 1.75 ratio 6-banger rockers on a SB head.
Ttt,
No opinions??
pdq67
post #3 of 9 (permalink) Old Oct 4th, 05, 10:07 PM
Paul
MCGOO's Avatar
PDQ,
If I recall correctly, the BB rockers can be used on the inline 6. I'm not 100% sure if it works the other way around. If it does, then that would be an affordable extra bit of lift woudn't it?
Paul
'69 Camaro, 250 inline 6, EFI Turbo rebuild is running!!
, CC5S TKO 500, and more.
V8 Camaros are like navels......Everybody has one.
The Toad. 1970 base Camaro (Navel), 350, turbo 700R4, 3.73 posi, Hotchkis TVS system,
Mrs. McGoo's & McGoo Jr.'s toy
MCGOO is offline
post #4 of 9 (permalink) Old Oct 5th, 05, 06:41 AM Thread Starter
That's why I brought it up is all.
Yes, a cheap "shade-tree" deal using a stud move and some bent valve covers for clearance to save some money.
I noticed that the new motors have high ratio rockers so why not on the old motor heads too...
And the old 348/409 "W" motors had high ratio rockers on them too...
pdq67
post #5 of 9 (permalink) Old Oct 5th, 05, 09:20 AM
Pdq67 the fulcum length is diffrent from the sbc. ver the six cylinder and the bbc.You have to relocate the stud to use them.It would be cheaper to buy the long slot 1.6 then to do all the machine work.
Rogers Performance is offline
post #6 of 9 (permalink) Old Oct 5th, 05, 05:44 PM Thread Starter
I know the fulcrum lengths are different and so require moving the studs, I was just asking if anybody had ever ran them is all.
You know, a good used set of 16, 6-banger rockers and cheap studs and some time on an endmill and there you go...
pdq67
post #7 of 9 (permalink) Old Oct 8th, 05, 11:15 AM
Paul
MCGOO's Avatar
Does this mean you actually have 'some time' to be able to fiddle with your car.
WOW............you must be living the good life
Paul
MCGOO is offline
post #8 of 9 (permalink) Old Oct 8th, 05, 11:51 AM
speaking of pdq's car and time to work on it, how bout an update? is that 496 still sleeping peacefully? will it ever move under it's own power? Haven't heard an apdate from you all summer, Paul!
post #9 of 9 (permalink) Old Oct 8th, 05, 03:55 PM Thread Starter
Unhappy Re: 1.75 ratio 6-banger rockers on a SB head.
I know, I'm sorry and haven't done anything to it lately..
Heck, the wife is even on my case about moving the old P/U out AND I still need to finish it too...
As Gomer would say, "For shame, for shame, for shame!".......
Bad, lazy pdq67 is all................
Lobe Separation Angle questions 69ProTouring Performance 19 Oct 10th, 05 06:41 PM
COMPRESSION RATIO, HEADS, AND PISTONS, OH MY! Scooby Doo Performance 6 Feb 18th, 04 01:20 PM
Cam Recomendation for 305, Head Question HawkZ28 Engine 2 Aug 4th, 03 05:30 AM
cylinder head lift values jks67SS396 Engine 5 Apr 18th, 03 04:54 AM
Possible to lower compression ratio with head chamber porting? Teetoe_Jones Performance 6 Nov 14th, 01 05:21 PM
