Quicker gas pedal ratio - Team Camaro Tech
post #1 of 4 (permalink) Old Oct 2nd, 05, 06:29 AM Thread Starter
Rick
Is there a means to quicken the gas pedal ratio so less travel will achieve WOT? My right ankle is a bit messed up and it's painful at times mashing the pedal. I figure less travel with a block to prevent overtravel would help.
Rick Dorion
69 RS Conv therapy program, Autogear M22, 8-pt cage, with a new 410! SOLD
New therapy program - 68 Coupe. Will be survivor exterior, modern underpinnings! SOLD
67 Belair with perfect floors, pinchwelds and firewall. Hmmm!
RickD is offline
post #2 of 4 (permalink) Old Oct 2nd, 05, 12:55 PM
Re: Quicker gas pedal ratio
If you can mount the throttle linkage closer to the shaft on the carb's throttle arm it should decrease the pedal travel.
69 RS 355 Tremec 5-Speed 4.11's
12run is offline
post #3 of 4 (permalink) Old Oct 3rd, 05, 06:38 AM
Bret
There was a trick shown in the Camaro Untold Secrets book of cutting out about 1" of length on the pedal arm and welding it back to gether to quicken the ratio on cross ram cars which use a 6 cyl cable style pedal.
Hope that helped a little?
Bret Copsey
'68 Camaro base coupe
'51 Chevy 3/4ton
bretcopsey is offline
post #4 of 4 (permalink) Old Oct 3rd, 05, 08:27 AM
Eric
Sorry to hear about the ankle problem Rick . . . that's the worst possible foot to have a problem with
Moving the cable AWAY from the pivot point (or higher) would increase the ratio but whatever you please make sure it won't bind up on you when you're done.
The other option would be to move the little ball that the cable snaps onto closer to the throttle shaft on the carb.
Eric68 is offline
Lokar gas pedal and cables Fathom rs/ss Engine 2 Jun 27th, 05 09:42 PM
Lokar gas pedal and cables Fathom rs/ss Engine 1 Jun 27th, 05 05:29 PM
69 Z gas pedal 69Z28 Engine 6 May 23rd, 05 06:32 AM
Gas Pedal Assembly Speedy69 Restoration Corner 6 Apr 19th, 05 10:05 AM
6:1 pedal ratio on a booster? dnult Brakes, Suspension & Steering 5 Jun 21st, 03 06:11 PM
