Engine ID anyone have a idea? - Team Camaro Tech
post #1 of 15 (permalink) Old Oct 3rd, 05, 09:23 AM Thread Starter
shawn
Casting # 3970010
Pad # V01062DA
It also has the 010 020 numbers cast into the rear of the block
Shawn
69 Camaro project started July 05 (wifes car)
85 Z28 Special ordered in late 84
slowdrive is offline
post #2 of 15 (permalink) Old Oct 3rd, 05, 10:25 AM
Re: Engine ID anyone have a idea?
3970010=1968/1976...350. I don't know about the other numbers.
deerhunter is offline
post #3 of 15 (permalink) Old Oct 3rd, 05, 01:13 PM
Vintage 68's Avatar
Question Re: Engine ID anyone have a idea?
Do you have the casting date?
And is it 1972...
1968 Convertible
Some trucks
Vintage 68 is offline
post #4 of 15 (permalink) Old Oct 3rd, 05, 01:47 PM
Its a 307 engine, originally used with manual trans. Same block # 010 as the 302,327,350, but its a 307.
Bob Brissie is offline
post #5 of 15 (permalink) Old Oct 3rd, 05, 01:55 PM
Bill
That is not just your regular 010 block.
That is an 010/020 block. It has an additional 1% tin and 2% nickel.
WildBillyT is offline
post #6 of 15 (permalink) Old Oct 3rd, 05, 02:57 PM Thread Starter
shawn
Here are some pics
Shawn
post #7 of 15 (permalink) Old Oct 3rd, 05, 04:23 PM Thread Starter
shawn
Ok just pulled the pan crank is 1130 which shows as forged 327.
Does anyone know how to tell the difference in the rods?
Shawn
post #8 of 15 (permalink) Old Oct 3rd, 05, 04:30 PM
So much for this 'Chevrolet Small Block V-8 Interchange Manual' by David Lewis! Sorry if I led you astray. This book is apparently not very good!
post #9 of 15 (permalink) Old Oct 3rd, 05, 04:44 PM Thread Starter
shawn
Thumbs up Re: Engine ID anyone have a idea?
lol I appreciate the input deerhunter . What might be throwing this off is that it didn't come out of a car.... but I know it is a all original engine..... just was trying to figure out exactly what I have (its lookin good so far). I am pretty sure it is a 69 or earlier.
Shawn
post #10 of 15 (permalink) Old Oct 3rd, 05, 06:46 PM
Smile Re: Engine ID anyone have a idea?
"DA".....
1965 to '67, 195hp/283, 2-barrel, 3-speed A-body, and
1968 to '69, 200hp/307, 2-barrel, 3-speed, A/F/X-bodies.
I bet it will bore .155" over EASY!!
pdq67
post #11 of 15 (permalink) Old Oct 3rd, 05, 07:14 PM
to many characters in that engine suffix code.
V01062DA
V=Flint Engine Plant
01= January
06=6th day of the month
2=?
DA = a 65 283 or a 68 307, neither of which used a 3970010 casting since it didn't reach production until April of 69.
All 70 and later 010 blocks destined for a car or truck should have a 3 digit suffix starting with either a C (cars) or T (truck).
If it was a mistamp of some kind there is a CDA suffix code that was for a 1972 L65 350/165HP engine with a manual transmission and a 2 barrel carb used in A and X bodies. There was also a 72 TDA coded engine which was a 307 ci engine used in C10's and C20's. There were other CDA and TDA coded engines but none within the time the 010 block was used (69 to 79).
Is there a partial VIN on the block, either on the engine pad, or down by the oil filter?
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
Mark C is offline
post #12 of 15 (permalink) Old Oct 3rd, 05, 07:39 PM
Whats the bore size?
oger is offline
post #13 of 15 (permalink) Old Oct 1st, 18, 05:15 PM
Probationer
Where was this engine pulled from? Looking at one with the same casting numbers/Engine ID
Sullychevelle is offline
post #14 of 15 (permalink) Old Oct 1st, 18, 09:13 PM
Vega$69's Avatar
This thread is 13 years since the last post and the OP hasnít logged on in over 5 years.
You might want to start a new thread
Vega$69 is offline
post #15 of 15 (permalink) Old Oct 1st, 18, 09:56 PM
Jon
Either that or simply read the old thread and become enlightened. It's a friggen 307, at least it is according to the original information, and the latest engine has the same stamping code, DA. Doesn't really take a brain sturgeon to figure that out.
*No disrespect meant or implied to any of the participants of this thread.* YMMV.
Jon N
dyno jonn is offline
2 1969 ZL1 Camaro Prototypes 68Baldwin Copo & Dealer 57 May 11th, 09 06:43 PM
Engine compartment upgrade idea? HOTRODSRJ Engine 137 Apr 4th, 07 12:54 PM
WHY KEEP ENGINE RPMS under 7000rpm grumpyvette Performance 50 Oct 4th, 05 10:39 AM
Engine kit for a built 406, or piece togather parts speedball1969 Performance 4 Apr 3rd, 03 08:58 AM
New Engine Break-IN Procedure (GM crate motor) sr71bb Engine 12 Dec 19th, 00 09:35 AM
