6223 steel crank - Team Camaro Tech
post #1 of 5 (permalink) Old Oct 3rd, 05, 02:13 PM Thread Starter
6223 steel crank
I recently aquired a 3855961 block dated Oct. 65, I assume that it is a 396 but the crank is confusing me, the only numbers on it are 6223 and the information that is on the internet is that it is either a 396,402, or 427 crank. Isn't there a difference between a 396 and 427 crank? If so how do you tell them apart?
russgt is offline
post #2 of 5 (permalink) Old Oct 3rd, 05, 04:06 PM
Re: 6223 steel crank
One of the counter weights is bigger on a 427 crank. If you lay a 396 and a 427 crank side by side you can see the difference.
oger is offline
post #3 of 5 (permalink) Old Oct 11th, 05, 06:10 PM
Alex
427 is #7115. That's a 396 crank. Same stroke and work the same. But a heck of alot less money!
dragsterman is offline
post #4 of 5 (permalink) Old Oct 12th, 05, 04:53 PM
The origonal crank in my L72 was a 6223. Cross drilled and large counter weight. I also have one that came out of a 396 no cross drill and the counter weight is turned smaller.
oger is offline
post #5 of 5 (permalink) Old Oct 12th, 05, 05:40 PM
Bill
russ,
366, 396, 402, and 427 all used the same 6223 crank forging at one time or another. The cranks were finish machined slightly differently due to balance issues, but the cranks are basically the same. They are all the same stroke. I have a 366 truck crank at the shop I am getting ready to use building a 427.
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
How to determine if a BBC came from factory with a steel crank? 40Coupe Performance 3 Oct 31st, 03 01:48 PM
Cast Steel or forged crank? CamaroJSU Performance 6 Aug 2nd, 03 06:36 AM
How do I tell if it is a cast or steel crank Cameron Performance 10 Jul 6th, 01 04:33 PM
350 cast steel crank Burney Tech 2000 6 Mar 26th, 01 06:12 AM
010 020 block with steel crank bowtie heads 74Z28 Engine 11 Jan 1st, 01 03:12 PM
