Re: New Distributor
If the old distributor is still in the motor.... make a mark on the valve cover where the vac can points, slowly pull the old one up just till the rotor doesn't turn anymore, and make a mark wherever it happens to be pointing. yank the old, slide the new in with the rotor pointing exactly where the old one did. The new one will stop about 3/8" from all the way down. Bump the starter and it will fall in the rest of the way. Turn the dist body until the vac can points at your other mark. Bolt it down, wire it and fire it up.
