motor mount question - Team Camaro Tech
post #1 of 6 (permalink) Old Oct 4th, 05, 06:01 PM Thread Starter
Andy
Send a message via AIM to 67SS&99SS
Question motor mount question
When I do my engine swap, I am going to put a set of hooker super comp headers on my 67 Camaro. I want to run the 1 3/4 primaries, and I was wondering which small block engine mounts I needed so that I wouldn't have to bash the primaries in order to clear the steering box. I have a set of 1 5/8" hedman headers now, and the tubes are dented in pretty good and are still touching the steering box. I have HEI now, and will run a smaller MSD distributor when I do the engine swap, so that is not an issue for me. Here is a picture of how it is now.
1967 Camaro SS: 406 sbc, 522hp/514 ft lbs, Doug's 1 3/4" headers, M20, posi, 3.73's, vintage air gen IV, IROC steering box, Comp Eng. weld-in sfc's & traction bars, chrome US Mags
67SS&99SS is offline
post #2 of 6 (permalink) Old Oct 4th, 05, 06:17 PM
Re: motor mount question
I use those headers on my 69. I have 307 frame stands and motor mounts, and no issues with the power steering box at all. However, I had to dimple one tube to clear the pitman arm. The driver's side header hangs pretty low, so be forewarned. And Hooker thought it a good idea to have the collector flange rotated so that on that header the bolt is at the bottom, which further reduces ground clearance.
BPOS is offline
post #3 of 6 (permalink) Old Oct 4th, 05, 07:45 PM
Craig
I run 1 5/8 Hooker Super Comps on my car with the standard 350 motor mount and it clears the steering box no problem.
thorpe67RS is offline
post #4 of 6 (permalink) Old Oct 5th, 05, 12:46 PM
George
Are you committed to the super comps? I just put a set of Doug's tri-y's (D375Y) on my 67 with stock motor mounts and have no clearance issues.
http://www.dougsheaders.com/applicat...turer.cfm?id=3
'67 convertible 210HP 327/Powerglide (not anymore!)
GunnerV is offline
post #5 of 6 (permalink) Old Oct 5th, 05, 04:27 PM Thread Starter
Andy
Thanks for the replies. I am going to run full length headers with 1 3/4" primaries. If there is another brand out there that fit better than the super comps with the same design, please chime in. However, I can't stand how those tri-y headers look. Definately not for me.
post #6 of 6 (permalink) Old Oct 5th, 05, 05:40 PM
Smile Re: motor mount question
Tri-Y's on a lot of hi-po street motor combinations run darn good even if they are funky looking.
And way back when they were the hot set-up until they started making high volume production runs of the more race oriented 4-tube, long jobbers..
pdq67
paint and X code question on my 69 RS diggerdave Tag Team 3 Sep 26th, 05 01:44 PM
79 power window question SirKnite Electrical & Wiring 0 Jul 28th, 05 05:10 PM
69 fuel line question - vapor return or not? Eric Kammerer Engine 7 Jun 11th, 05 07:08 PM
Front glass install question Brackneyc Body Shop 12 Jun 11th, 05 11:40 AM
Non Camaro question which tuner for my trucks? MStennes Bench Racing 5 Dec 6th, 04 09:08 AM
