Pertronix - Team Camaro Tech
post #1 of 9 (permalink) Old Oct 5th, 05, 11:58 AM Thread Starter
Phil
Question Pertronix
Just curious to hear comments from those that have replaced their points with a Pertronix Ignitor kit. I have a 69 w/396 and was considering making the switch. They offer two versions: Ignitor and Ignitor II. Which is preferred?
Thanks,
Phil
SixtyNiner is offline
post #2 of 9 (permalink) Old Oct 5th, 05, 01:14 PM
Wes
Re: Pertronix
I use the Pertonix Igniter I on three cars (part # 1181, I believe). I highly recommend it...best $100 you'll spend.
I also recommend their 40,000v Flame-Thrower coil but it requires a full 12 volts...your stocker uses about half that, because a full 12v will quickly fry the points. A resistor wire from the ignition to the coil is used to reduce the juice to the coil,..so you'll have to replace it with a 12 or 14g braided wire or run a jumper from your fuse box (from the connector that says "IGN") to the coil.
After insalling both, you'll have a stock-looking and fitting ignition that is very stable that will rev to 7000 with no problems. You'll also find that cold starts are much improved.
Search "Pertronix" on this site,..you'll find many who are fans,..very few who aren't.
Good luck!
Straight-line-69 is offline
post #3 of 9 (permalink) Old Oct 7th, 05, 01:01 PM Thread Starter
Phil
Re: Pertronix
Hello and thank you for your response!
I appreciate your opinion and thanks for the info on the coil as well. I think I'm going to install a Pertronix system over the winter while my baby sleeps!
Phil
post #4 of 9 (permalink) Old Oct 7th, 05, 04:50 PM
Smile Re: Pertronix
I installed it on my 67' and have never had a problem. Installation was easy and as previously posted, cold starts were better, idle smoother, and you never have to mess with points again.
67 Plain Jane is offline
post #5 of 9 (permalink) Old Oct 7th, 05, 05:00 PM
Mike Petrovich
Re: Pertronix
Ignitor 1 in my 68 along with flame thrower coil, no problems yet.
1968 327 sport coupe. Son of original owner.
mike p is offline
post #6 of 9 (permalink) Old Oct 7th, 05, 06:17 PM
Sean
Re: Pertronix
had one a couple years ago (first design i believe), worked well, while it worked. it was fine then one day just crapped out. exchanged it for another one, and it never worked right, its sitting on a shelf still. i went to an hei, now running all msd stuff. the hei ran as well or better than the pertronix, when it worked.
do a search of this site on them, lots of mixed results.
hopefully they have them working well now, they are a nice idea, but you are still running them in an old distributor. i would go hei first, myself.
just one mans opinion
Sean
Franklin D. Roosevelt
68rs406 is offline
post #7 of 9 (permalink) Old Oct 7th, 05, 06:24 PM
Turd Fergeson
ZZMike's Avatar
Re: Pertronix
I'm kind of in the same boat as 68rs406; the first one worked great until went toes up suddenly, and the second never worked right.
1968 British Racing Green Crossram Camaro Z/28
Double Trouble
2016 Black Corvette Z06/Z07
ZZMike is offline
post #8 of 9 (permalink) Old Oct 7th, 05, 07:57 PM
ZZ_430's Avatar
Re: Pertronix
I have 2 friends that tried the whole setup on Chevy trucks.
A couple of years later, they eventually both came in on a hook...no spark...no start.....stranded along side the road.
It's hard to beat a good HEI.
Don ~ TC Member #15 ~
Don't mess with Texas!
ZZ_430 is offline
post #9 of 9 (permalink) Old Oct 9th, 05, 03:36 PM
Re: Pertronix
Just FYI, the CRANE XRI is a pretty cool little device with a rather simple rev limiter. I installed one in my distributor with ease, and checked for a spark by just spinning the Dist shaft slowly by hand. Got a good hot spark, very simple.
Rob
Thanks,
Phil
Robert
'69 X-33 since 1984
"Its all crazy..."
olympic69 is offline
Wells VR715 Voltage regulator and Pertronix Ignition Granny's 69 Electrical & Wiring 6 Sep 25th, 05 09:32 AM
Installing Pertronix Coil - Where is Ballast resistor Located? Granny's 69 Engine 3 Aug 22nd, 04 08:54 AM
Pertronix L e F t C o A s T7 Electrical & Wiring 2 Aug 2nd, 02 04:01 PM
pertronix again Frank350 Electrical & Wiring 5 Jul 18th, 02 12:43 PM
pertronix ignition problem or carb? 250 straight 6 camaro johnmilner Troubleshooting 3 May 1st, 02 10:32 AM
