2 easy questions about 350 block - Team Camaro Tech
post #1 of 4 (permalink) Old Oct 9th, 05, 05:14 PM Thread Starter
mark
I got a 350 for free so I'm going to do my first rebuild. My question is on the back of the block theres 2 freeze plugs on the left and right. In the center directly behind the cam is that another? I wasn't sure so I didn't pop it out. Also the dipstick is on the passenger side, Iv'e never seen this on a SB before.
sick67 is offline
post #2 of 4 (permalink) Old Oct 9th, 05, 06:03 PM
Banned
Re: 2 easy questions about 350 block
All the small blocks I have worked on have had freeze plugs on the rear of the block and they have had a cam plug behind the cam on the rear and the block you have maybe a 81 to 85 block 2 peice rear main seal or if it is a 1 peice seal it is 86 and up.
CNC BLOCKS N/E is offline
post #3 of 4 (permalink) Old Oct 9th, 05, 07:15 PM Thread Starter
mark
should I pop the cam plug out or just leave it alone?
sick67 is offline
post #4 of 4 (permalink) Old Oct 9th, 05, 07:44 PM
Banned
To get the old cam bearings out it will have to be removed and a new one comes in the freeze plug kit.
Largest CID from a 350 block? Barefoot Dave Engine 4 Oct 4th, 04 07:58 AM
BB frame mounts further forward than small block camcojb Engine 24 Jun 28th, 03 10:23 AM
350 small block out of olds. peters76 Performance 8 Nov 18th, 02 12:36 PM
How to Store Bare 350 Block?? TEAM CANADA Engine 5 Nov 15th, 01 04:49 AM
