69 Camaro convert 305 small block to 400 small block - Team Camaro Tech
post #1 of 5 (permalink) Old Oct 9th, 05, 08:10 PM Thread Starter
i have a 69 camaro with a 305 small block. i found a 400 small block from a 1973 chevy truck and was wondering if i needed to mod anything to replace the 305 with the 400?
P0RCH is offline
post #2 of 5 (permalink) Old Oct 9th, 05, 08:40 PM
Re: 69 Camaro convert 305 small block to 400 small block
basically, no. Remember the 400 is externally balanced, you have to use the balancer and flexplkate that came with it. Everything will bolt in tho. Get ready for some serious torque!
post #3 of 5 (permalink) Old Oct 10th, 05, 04:50 AM
Jim is correct. Only problems I see is getting that smile off your face and replacing rear tires a lot. LOL
You may need to upgrade your radiator to a 3 or 4 core but otherwise it's drop-in.
68 Camaro~LSx ~all motor
post #4 of 5 (permalink) Old Oct 10th, 05, 12:00 PM
Jerry
Send a message via MSN to blackvi
P0rch,
Ditto on what Doug says!
(Note: Doug owns a nice 406 himself. So he knows a little something about removing smile spasms from his face)
Might want to consider either freshening up the tranny in your ride or having an aftermarket one put in. I would also get some fresh rubber for the wheels. They are gonna hate you!
Jerry - Systems Specialist, IT consultant, Hot Rod Enthusiast -- Searching for a way to tap into the hidden strengths that all stroked SBC’s have. Then one day, an accidental overdose of Camaros.net altered my body chemistry.
blackvi is offline
post #5 of 5 (permalink) Old Oct 11th, 05, 05:48 PM
Alex
And don't forget to throw that boat anchor of a 305 in the lake when your done!
dragsterman is offline
more readings I found on up-coming camaro JFINN1976 Bench Racing 2 Oct 23rd, 04 08:37 AM
5th Gen Camaro in 07? 69ProTouring Bench Racing 6 Sep 16th, 03 12:24 AM
400 small block Murdock Tech 2000 10 Jun 12th, 01 05:08 PM
400 small block going into my car CamaroZ28man Tech 2000 4 May 29th, 01 01:12 PM
400 small block CamaroZ28man Tech 2000 7 Jan 30th, 01 01:18 PM
