Oil going up head bolt threads - Team Camaro Tech
post #1 of 4 (permalink) Old Oct 10th, 05, 08:27 AM Thread Starter
"Tri-Tip"
Gary L's Avatar
On my Dz rebuild with only 200 miles or so I notice black oil around the driver side front bottom bolt. It is not the valve covers, definitely the bolt. Why would it be so black when the oil in the pan is clean? Does this bolt hole go thru to an oil passage?
Gary L is offline
post #2 of 4 (permalink) Old Oct 10th, 05, 09:47 AM
Re: Oil going up head bolt threads
No. It goes into the water jacket.
'67 SS/RS (RR)
'68 RS conv. (J2)
'68 Z/28 (VV)
'68 Drag Car(ZZ) 11.30 @ 118
'73 Corvette Drag Car 12.64 @ 106
Kyvox is offline
post #3 of 4 (permalink) Old Oct 10th, 05, 10:18 AM
As John suggests, the bolt goes into the water jacket. It may be the coolant weeping up the threads, coming out from underneath the bolthead, and dirt in the air, remember the fan in front, mixing with the coolant.
You might sprinkle the area with either Martha White Flour or talcum powder to see if there are trails from another source.
post #4 of 4 (permalink) Old Oct 10th, 05, 07:54 PM Thread Starter
"Tri-Tip"
Gary L's Avatar
If it coolant it is black nasty stuff. I have a feeling that I am not done with intake vacuum leaks and oils is working it's way out somehow. I put new plugs in so I can start from scratch and monitor the plugs. The plugs I started the engine with have been thru intake leaks and some were dirty/oily.
Gary L is offline
If I'm missing an intake to head bolt, is it ok? Josh69 Engine 12 Sep 9th, 04 10:57 AM
what are the head bolt torque specs? speedy-Z Performance 4 Jan 28th, 03 02:09 PM
What head bolt kit to use with aluminum heads? 68Hugger Engine 7 Mar 6th, 02 05:16 PM
head bolt?????? 88camaroRS Tech 2000 5 Apr 24th, 01 12:15 PM
Vortec Head Bolt Toque? Torch Tech 2000 2 Dec 25th, 99 06:23 PM
