Holley Tuning. - Team Camaro Tech
post #1 of 2 (permalink) Old Oct 10th, 05, 07:03 PM Thread Starter
Derek
Holley Tuning.
Got my motor running and my carb is very rich. Holley 6210 spreadbore 650. It has a constant drip out of the secondaries while idling. Havent tuned on a holley before so any advice would be great. Also where can I find a guage to measure vacuum. Cam has a good lope so I might be low on vacuum.
dtm1968 is offline
post #2 of 2 (permalink) Old Oct 10th, 05, 07:31 PM
Craig
Re: Holley Tuning.
Dripping out the secondaries would indicate that your float is to high or stuck or crap in there. If you have the screws that allow you to adjust the float levels you probably want to lower it. If no adjusting screws pull off the bowl and bend the little arm to lower the float. This happened with my Holley when it as brand new, i didnt have adjusting screws on mine and had to pull the bowl and bend the arm. Just go easy, a very small adjustment is all you'll probably need.
thorpe67RS is offline
Holley Tuning Advice? JST12 Engine 11 Jan 22nd, 04 02:14 PM
1st timeslip from new combo, please comment Camaro76350 Performance 5 Nov 16th, 03 01:52 PM
Out of the box Holley 3310 carb tuning. Mike68RS Performance 12 Feb 9th, 03 03:10 PM
Holley Tuning Bedanobub Engine 8 Mar 11th, 02 02:24 PM
Holley 750 Tuning Question Dans67 Performance 13 Aug 27th, 01 01:19 PM
