2601 Edelbrock - Team Camaro Tech
post #1 of 5 (permalink) Old Oct 11th, 05, 07:46 PM Thread Starter
2601 Edelbrock
Has anyone installed a 2601 Performer Air-Gap Edelbrock on a 350 / 300HP with a Cowl Hood? The old clearance question.
Thanks Dave
Hedkat is offline
post #2 of 5 (permalink) Old Oct 12th, 05, 06:52 PM
Re: 2601 Edelbrock
Cleared my cowl hood and sealed well.. Had problems with upper alt bracket not fitting.
TC # 349
zdld17 is offline
post #3 of 5 (permalink) Old Oct 12th, 05, 07:45 PM
Craig
Re: 2601 Edelbrock
If you set the air gap and the performer rpm side by side and line them up they are basically the same height. Should be no problem whatsoever.
thorpe67RS is offline
post #4 of 5 (permalink) Old Oct 13th, 05, 05:54 AM
Re: 2601 Edelbrock
I have a flat hood, Vic Jr. intake, drop base 3"tall air cleaner, and about 3/4" clearance.
68 Camaro~LSx ~all motor
post #5 of 5 (permalink) Old Oct 13th, 05, 06:56 AM
Re: 2601 Edelbrock
The manifold side by side is the same with in 1/4 " ,, its the mounting position of the upper alt bracket from water pump to thermostat bolt mount hole that I had problems with... I made an adjustment bracket out of an older bracket but it does not look hi tech... so I got a low mount from Mach people that came with a kool adjustment jack rod.
TC # 349
zdld17 is offline
Edelbrock carb problem? fuel drip, hesitation and backfire -please HELP! mr69 Troubleshooting 6 Aug 7th, 11 08:06 PM
Which Edelbrock? B Arnold Engine 12 Nov 13th, 05 06:57 AM
Edelbrock Carb performance help MrDanB Performance 4 Apr 7th, 05 07:27 PM
Edelbrock Heads JefeOsterhead Engine 8 Oct 28th, 02 02:19 AM
Edelbrock 1721 Fuel Pump in 1st Gen memcgraw Engine 12 Aug 18th, 00 02:30 PM
