Over fed 350 - Team Camaro Tech
post #1 of 4 (permalink) Old Oct 11th, 05, 11:10 PM Thread Starter
Brad Cushman
Over fed 350
My 67 SS/RS has a '73 vintage 350 cid fed by a Holley 80508-1 750CFM Model 4160 / Weiand 8004 intake manifold. The engine has camelback heads that I don't know anything about yet.
I drive this car in Albuquerque (6000'). I jetted the carb down from 72 to 68 to stop a rich run problem. I was advised to advance the timing to 12 degrees to augment the 68 jet. I am getting clues from this forum that the Holley 750 may be too much carb for this engine and therefore difficult to tune.
I have not tested for vacuum but the brake booster is slow to recoup after the first brake application with the engine at idle. I have also not tested compression yet.
Does anyone have an opinion on this carburetor for this engine?
Brad Cushman
'67 SS/RS
cushjbc is offline
post #2 of 4 (permalink) Old Oct 12th, 05, 05:40 AM
Re: Over fed 350
yes I have an almost exact setup but edelbrock intake and my 750 is perfect. idles where I want it and has great throttle response. Kenny
kennys is offline
post #3 of 4 (permalink) Old Oct 12th, 05, 04:59 PM Thread Starter
Brad Cushman
Re: Over fed 350
Kenny,
Thanks, I will pursue the tune of this carburetor by following Holley website clues with respect to idle mixture via vacuum test, float levels and then proceed to timing. Do you have any advice on tuning that you are willing to share with a novice whose setup is similar to yours?
Brad Cushman
'67 SS/RS
cushjbc is offline
post #4 of 4 (permalink) Old Oct 12th, 05, 05:52 PM
Re: Over fed 350
I had problems cruising to Clovis, Nm running 72 jets and thats about 4k ft mark. Further south I went , smaller the jet as air is more dense. You may have to do some experimenting or plug reading...
TC # 349
zdld17 is offline
350 diesel?? oddrod Engine 8 May 21st, 05 12:55 AM
Which engine??? 350, 355, 383, 400, 406 speedball1969 Engine 13 Apr 5th, 02 06:22 AM
BIg Block Info I got off the web! Very long! pdq67 Performance 6 Jan 5th, 02 03:08 PM
LOS assembly plant SS 350 real or not? TXSS Tag Team 4 Aug 1st, 01 02:34 AM
Camel Hump heads---Good choice for 1984 350? 79Z28Camaro Performance 4 Apr 27th, 01 07:08 AM
