In search of a BB question - Team Camaro Tech
post #1 of 7 (permalink) Old Oct 14th, 05, 08:04 AM Thread Starter
Hi All- I have sort of an odd request Im hoping someone can help me with. From time to time I come across someone who has a BB stored “in the back of the garage for years”. Now I don’t really need a BB at this time, however for some strange reason Im compelled to own one just in case I ever pick up car that I want to drop it in. ( I was toying with the idea of yanking the 305 (non –matching) out of the 76 camaro I have in the back of the shop and putting a BB in…maybe when my son gets older..) Im not set on any particular CU either. I would appreciate any info about if there are particular YEARS or CASTINGS that I should really pass on and conversely any years, castings etc that I should jump on on the spot?? Any other tips on what to look for under all that oil and grease is appreciated. dave
diggerdave is offline
post #2 of 7 (permalink) Old Oct 14th, 05, 08:07 AM
Bill
Re: In search of a BB question
Honestly, you should get the numbers off of it and post it here. I can't think of any big block you really should avoid, although truck blocks and peanut port heads are typically not as desireable as others.
By the way, in order to put a big block in your '76 you will most likely need a new hood to go with it, or use an LS-5 or Torker II manifold. Everything else will be too tall.
WildBillyT is offline
post #3 of 7 (permalink) Old Oct 14th, 05, 08:16 AM Thread Starter
Thanks Bill - thats my understanding on truck blocks as well. Not sure what the peanut port heads are tho? Thanks for the info. dave
post #4 of 7 (permalink) Old Oct 14th, 05, 08:49 AM
Bill
Peanut port heads have small oval ports. They are not as good as large oval port heads or rectangular port heads for performance as they do not flow very well. That's not to say that they are bad; you can still get decent power from them. They were mostly used on trucks for low end grunt.
The best of the oval port heads are the castings whose numbers end in 049 or 781.
Note the port size on the heads, those are peanut ports.
post #5 of 7 (permalink) Old Oct 14th, 05, 08:51 AM
It's all about the castings, so I've found. I bought a 454, I had the block casting numbers and I found the block was a '71 454 block... that's great, but then when I got it home I looked up the head casting and found they were TRUCK HEADS from about 1980. From everything I've read the PEANUT PORT heads were used on Trucks, they have very small port openings, about the size of a PEANUT. They make good low end power but drop off at about 4000 RPM. Not ideal for a street/strip car unless you plan on towing your boat down the 1/4 mile.
So I've been hunting down another set of heads. I've found these two sites are a great resource.
http://www.kendrick-auto.com/casting_numbers.htm
http://www.mortec.com/bbc.htm
If you find someone selling a block or heads or both, ask them to get the casting numbers for both the block and heads, or get them yourself and then look them up here and that will tell you alot of what you're looking at.
-A
CaliforniaFats is offline
post #6 of 7 (permalink) Old Oct 14th, 05, 08:55 AM
Bill
Oh, and one other thing- "HI PERF" typically won't mean too much. It was cast into all big blocks till around '91 IIRC.
post #7 of 7 (permalink) Old Oct 14th, 05, 05:16 PM
Smile Re: In search of a BB question
If the ports are wider than they are tall, they are peanut port heads!
And they are usually around 200 cc's or so.. Open chambers, I think?
The Vortec, L29 head that replaced them comes in as a true, although small large oval port head but generally they are around 230 cc's or so! It' s good small head b/c it has a very good modern 100 cc, heart-shaped, open chamder design!
And there are true large ovals run from 235 up above 260 cc's!! Open, semi-closed AND closed chambers....
Plus smog, or open-chambered large oval heads that you tell b/c the quench by the exhaust valve is almost totally gone and the chamber is squared up with the intake valve lines..
pdq67
housecleaning and search question? JimM Camaros.net Site Help Discussion 3 Feb 16th, 05 07:28 AM
Search function question?? GDV350SS Camaros.net Site Help Discussion 2 Jan 13th, 04 04:54 PM
Th350 - Flexplate to Torque Conv. question & other issues. Granny's 69 Engine 6 Feb 11th, 03 04:49 AM
Quick Muncie Question 68moneypit Engine 6 Jul 28th, 01 06:11 AM
Gear question for the speedometer bilydean Tech 2000 9 Apr 17th, 01 12:46 PM
