1984 z28 305HO to 350 HO swap question. - Team Camaro Tech
post #1 of 4 (permalink) Old Oct 14th, 05, 11:21 AM Thread Starter
I am beginng a project in which I plan to swap the 305 HO in my old 1984 Z28 with a new 350HO. The 350 that I bought can be seen here : http://www.crateenginedepot.com/stor...29-P824C0.aspx.
I plan on purchasing a new intake manifold ( vacuum leak) and possibly a carb if needed.
The car will be used on the street and must pass massachusetts emissions. Due to a low budget I would like to reuse what I can from the old 305.
Does anyone have tips or advice for this project?
Thanks,
Fred
Ffrizzell is offline
post #2 of 4 (permalink) Old Oct 14th, 05, 05:53 PM
Vince
Re: 1984 z28 305HO to 350 HO swap question.
Sorry for the long post, but this car touched my heart....
I had a 85 T/A carb'd 305 and 700r4 with some stall. Put a 350 w/9:6:1 hypers, stock heads, ran a Comp Computer cam (dont know why, seemed like a good idea at the time), RPM, and stock Q-Jet. I used Edelbrock headers for a 5.7 Iroc (bigger). All emission stuff hooked back up, carb was computer controlled. Car ran best 14.0, spinning the one-legger 1st through 2nd till it hooked. Dont know what the rear was, probably 3.08's. Computer was fine - no check engine light, and a good idle. COuld of used more cam. I'm confident that if I sent the carb in for rework, got posi and some stickes, that car would of ran 12's easy. BTW, I ran 87 octane cause I was poor at the time. Engine was 900 rebuilt, 140 intake, 330 headers. Nice kick-*** package
Only problem was that the car killed transmissions. Killed 2 700's, and the 3rd trans died on the kid that bought it from me. I suspect that the 700r4's dont like being shifted at 6500+ rpms.
VINCE
69 CHEVELLE SS
502 EFI/[224/228 HR]/T56/3.90
*1.8/11.59/124.34*
SIDEWAYS is offline
post #3 of 4 (permalink) Old Oct 14th, 05, 05:57 PM
Vince
BTW, everything was COMPLETE bolt in. The Eddy headers though b/c they were designed for 5.7 Iroc, the divirter valve on the exhaust didnt fit right. Those stock GM F-body exhausts need to come off!!!
VINCE
69 CHEVELLE SS
*1.8/11.59/124.34*
SIDEWAYS is offline
post #4 of 4 (permalink) Old Oct 14th, 05, 07:10 PM
BonzoHansen's Avatar
Thanks,
Fred
Try here --> http://thirdgen.org/techbb2/
Watch the manifold choice...many do not have EGR provisions. You need that for emissions.
Does this disclaimer "should be used in 1979 and earlier pre-emissions street vehicles or any off road usage" bother you at all? It sounds pretty mild, so it wouldn't bother me too much, just asking.
TC Member #13
BonzoHansen is offline
T56 swap into SB Chevy (Starter Question) rjrock Tech 2000 1 May 22nd, 01 05:13 AM
305 to 350 swap 85z28 Tech 2000 2 Apr 19th, 01 03:48 PM
305 to 350 swap..91 Rs 91RsLO3 Tech 2000 2 Mar 18th, 01 02:47 PM
4.3 Vortec to 350 V-8 Swap highstakes Tech 2000 4 Feb 28th, 01 04:31 PM
engine and tranny swap question jim rex Tech 2000 3 Jul 1st, 00 06:47 PM
