V-6 and V-8 swap- need help! - Team Camaro Tech
post #1 of 3 (permalink) Old Oct 14th, 05, 03:42 PM Thread Starter
Question V-6 and V-8 swap- need help!
I have a 85 Camaro that had a V-6 engine. I just bought a 89 Camaro with a V-8 (both fuel injected).
The V-8 went engine sat into the 85 with no problem, but the V-6 engine motor mounts will not line up in the 89.
In addition, having electrical problems with the 85 since the V-8 has been installed.
All the help and advice possible would be greatly appreciated!
dennine3003 is offline
post #2 of 3 (permalink) Old Oct 14th, 05, 07:16 PM
BonzoHansen's Avatar
Re: V-6 and V-8 swap- need help!
I can't really help with the mounts, but try here ---> http://thirdgen.org/techbb2/
What kind of electrical?
TC Member #13
BonzoHansen is offline
post #3 of 3 (permalink) Old Oct 16th, 05, 12:59 PM
what you need to do is cut the mounts and remount for the V8... V6 and V8 mounts dont work together because of block size
Racing_Master is offline
BB Starter Swap Help SS 396 Engine 3 Sep 28th, 05 09:08 PM
LS1 Swap 1PimpinZ28 Camaro Tech 6 Jun 24th, 05 12:11 AM
LS1 T56 Swap rmadsen55 Transmission & Driveline 2 Mar 28th, 05 06:29 PM
engine mods and swap cherokeeman Performance 4 Aug 22nd, 03 01:09 AM
What is needed to swap a 4 speed to a turbo 350 in a 69 camaro? wildmoose Engine 3 Feb 4th, 00 09:53 AM
