balance flywheel - Team Camaro Tech
post #1 of 3 (permalink) Old Oct 14th, 05, 11:11 PM Thread Starter
Jerry R.
jr68's Avatar
balance flywheel
My new clutch has a different bolt pattern so I must drill 3 new holes in the flywheel ( already resurfaced )
I'm a machinist and can take this to work and place the bolt circle in the right spot so that part is no problem.
What I need to know is should the flywheel be rebalanced after I'm done ?
my Magnaflow X-pipe system sound clip, click the link
jr68 is offline
post #2 of 3 (permalink) Old Oct 15th, 05, 01:40 AM
Re: balance flywheel
Your new holes will be evenly positioned around the axis, then you will not be altering the balance. Naturally, all the holes will be of identical diameter so an even amount of material is removed from each hole.
The existing holes and your new holes will have a "neutral" or no effect on the flywheel's balance.
BlackoutSteve is offline
post #3 of 3 (permalink) Old Oct 15th, 05, 05:32 AM
Banned
We always balance the flywheel after its been resurfaced and once the flyweel is balamced we put the pressure plate on a balance that as well and index the pressure plate to flywheel so they are assembled in the same spot and where your drilling new holes this should be done.
CNC BLOCKS N/E is offline
454 Flywheel Balance... INT or EXT? CaliforniaFats Engine 4 Oct 8th, 05 04:03 PM
weber flywheel dusted800 Engine 5 Jun 9th, 04 03:38 PM
centerforce clutch + stock flywheel Neals69SS Transmission & Driveline 15 Mar 11th, 04 02:36 AM
Pressure plate to flywheel Tire Smoke 69 Transmission & Driveline 4 Sep 20th, 03 04:02 PM
SB Flywheel on BB jmar Engine 16 Jul 6th, 02 04:05 AM
