Coil Wire - Team Camaro Tech
post #1 of 7 (permalink) Old Oct 15th, 05, 06:03 PM Thread Starter
Kevin
Coil Wire
Does anyone know if MSD makes a coil wire that plugs into a HEI cap (female) and the other end (male) that plugs into the blaster coil?
67 Camaro rs/350 HO(est. 401hp)/4L80E/8.5" 10 bolt 3.73
Sixty-Seven rs is offline
post #2 of 7 (permalink) Old Oct 16th, 05, 08:36 AM
Re: Coil Wire
If not you could always make one.
69 RS 355 Tremec 5-Speed 4.11's
12run is offline
post #3 of 7 (permalink) Old Oct 16th, 05, 09:23 AM Thread Starter
Kevin
Re: Coil Wire
Yeah thats true. I have never did that before. Any tips on how it should be done? You need a special crimping tool?
post #4 of 7 (permalink) Old Oct 16th, 05, 11:09 AM
Re: Coil Wire
Summit sells a nice racheting crimp tool for $40.
12run is offline
post #5 of 7 (permalink) Old Oct 16th, 05, 02:46 PM
Re: Coil Wire
why do you need a coil wire for HEI which has the coil built into the cap?
400bird is offline
post #6 of 7 (permalink) Old Oct 16th, 05, 03:39 PM
Call me Funk
Send a message via AIM to CFunK
Re: Coil Wire
MSD does not have the coil built into the cap, the coil is external.
I recommend picking up the crimp tool. Tony let me borrow his a few weeks back to make a custom set of wires for the '67 and it works slick. It's always nice to make the wires fit and not use a universal set.
-Funk
CFunK is offline
post #7 of 7 (permalink) Old Oct 17th, 05, 04:17 AM
Alex
Re: Coil Wire
Go to Summitracing.com 1-800-230-3030 .They will know if one is made. Probably wouldn't be too hard to make one or just buy one. MSD makes the set up, so I am sure they sell the correct wires.
dragsterman is offline
PO 300 301 302 OBD II 3L 4P Bench Racing 9 May 6th, 05 08:02 PM
Generator light, coil, resistance wire, ignition switch? mr69 Troubleshooting 2 May 29th, 04 08:17 PM
welding....need help 69ss350camaro Body Shop 3 Apr 3rd, 03 02:20 PM
Expanded MARTINSR Body Shop 11 Jan 15th, 03 02:57 PM
ignition coil +resistance wire getting extremely hot jlighthart Electrical & Wiring 1 Jun 4th, 01 12:57 AM
