double hump rebuild - Team Camaro Tech
post #1 of 6 (permalink) Old Oct 16th, 05, 07:14 AM Thread Starter
double hump rebuild
I am getting a set of 1.94 double humps rebuilt for a weekend driver, no heavy abuse. Could I just put bigger valves in to increase intake to 2.02 or do I need machine work?
As far as valves/springs etc. should I get original or are there newer components to increase driveability, h.p., reliability etc.?
What shouldit cost to get this done at machine shop?
Thanks all,
Bluesdog
bluesdog is offline
post #2 of 6 (permalink) Old Oct 16th, 05, 07:29 AM
Re: double hump rebuild
You just can,t put 2.02 valves in you have to open them up for it.
If you really want it done wright you will also need to do the chamber wall and the bowl area.
If you do every thing wright new parts Using Gm studs and guide plates new springs up grade for harden seats.
I just bought a set of 291 and did all the work to change them to 2.02 and 1.600 including everything listed above it would have cost some one $1,500 to do all the work if they had to buy castings to.
Rogers Performance is offline
post #3 of 6 (permalink) Old Oct 16th, 05, 12:13 PM
Smile Re: double hump rebuild
GM plunge cut the chamber walls around the valves and if you can look at a pair of factory big valve heads, you can see and feel it.
And like said, they won't flow as good as medium valve heads w/o the plunge cuts b/c of too much shrouding next to the tall chamber walls.
You will see what I mean...
pdq67
post #4 of 6 (permalink) Old Oct 17th, 05, 04:27 AM
Alex
Save your money! It will cost you way more than the heads are worth to change the valve size. Buy a set of Darts or something like that. Even the S/R Torkers will give you the same or better power than GM double humps. I see them on EBay for about $600. New and fresh. I was going to change a set of 186 heads from 1.94s to 2.02s and the machine shop wanted like 800-900 to do all the stuff needed. But that was doing everything, cutting them for larger springs, screw in studs, guideplates hardened seats etc. I bought some new Dart Iron Eagles for $909 shipped to my door off EBay. Way better heads for less money! The only way I would blow that kind of money on a stock set is if they were correct for your car or something like that. Save money and buy someone Else's past mistakes for less!
dragsterman is offline
post #5 of 6 (permalink) Old Oct 17th, 05, 06:01 AM
Kevin
KevinW's Avatar
bluesdog, you know you will loose some low end torque by going to 2.02. A Z needed that size because the motor ran such high rpms. For street use on a midrange engine 1.94s work just fine. Then all you need is a normal head rebuild (less $$). BTW, What are the casting numbers and date codes of those heads?
Kevin
KevinW is offline
post #6 of 6 (permalink) Old Oct 17th, 05, 02:46 PM Thread Starter
Kevin, they are the 3917291 casting numbers and the date codes are B-27-8 and B-29-8, athough my car is later year 68. Been manaflixed and cleaned. Studs holes are screw type.
Thanks to all - I'll probably just keep them 1.94's and save cash for something else.
Bluesdog
bluesdog is offline
Double hump heads spark plug Q Kyson Engine 9 Aug 21st, 05 11:14 AM
Double hump heads? Hobbes9112 Performance 87 Dec 24th, 04 07:07 PM
Double hump heads 1990SS454 Engine 4 Nov 26th, 02 03:34 PM
double hump heads?what do i have David Bryant Engine 6 Apr 22nd, 02 10:30 AM
Are these Double Hump heads? Old School Tech 2000 3 Aug 8th, 01 10:50 AM
