PCV routing question - Team Camaro Tech
post #1 of 7 (permalink) Old Oct 17th, 05, 04:51 PM Thread Starter
My 1982 350 going in my 67...how should I route a pcv valve system?
edcorsaro is offline
post #2 of 7 (permalink) Old Oct 17th, 05, 04:57 PM
Re: PCV routing question
One should go to the carb base plate and the other to the air cleaner.
Rogers Performance is offline
post #3 of 7 (permalink) Old Oct 18th, 05, 11:13 AM
Vintage 68's Avatar
Question Re: PCV routing question
Are you planning on retaining the '67 Intake Manifold or using the '82 parts?
1968 Convertible
Some trucks
Vintage 68 is offline
post #4 of 7 (permalink) Old Oct 18th, 05, 11:50 AM Thread Starter
I am running Weind tunnel ram. Both valve covers (Moroso tall) have a spot for pcv. I am building this from scratch so I really don't know what I need, it is in a 1967 camaro. I need a diagram or something like that. Thanks
post #5 of 7 (permalink) Old Oct 18th, 05, 12:03 PM
Vintage 68's Avatar
Since you are not using the '67 parts you can proceed as was said in the other reply.
You just need to install the PCV in one cover hole, (the factory used the left (driverside) valve cover.
Then install the necessary fittings and tube in the other valve cover to the air cleaner base, on the inside of the filter element.
You could also just install a 'breather' in the other hole v.s. routing to the air cleaner base - but, the air cleaner hook-up is better.
Hope this helps;
1968 Convertible
Some trucks
post #6 of 7 (permalink) Old Oct 18th, 05, 01:55 PM
Am I reading too much into this post? If he's doing a tunnel ram, he's obviously going to run it at WOT at the track and don't need no PCV system.
However, if he's bound and determined to run a street set-up, he'll need to run a hose from the valve cover mounted PCV valve to the carb base plate, a controlled vacuum leak. He'll have to place a vented cap on the other valve cover to circulate air as Vintage & Rogers suggest.
post #7 of 7 (permalink) Old Oct 18th, 05, 09:48 PM Thread Starter
Not planning on taking it to the track. Just want to run it on the street. I used to run a ram on a 283. It ran fine.
Question about valve covers/PCV routing with new intake manifold cam1967rsss Engine 13 May 24th, 11 06:53 PM
PCV Valve/Breather Question thorpe67RS Camaro Tech 6 Sep 21st, 05 05:57 PM
Air Cleaner PCV Hookup for 68 RS/SS SB Manual w/A.I.R aburgess Restoration Corner 0 Sep 8th, 05 06:12 PM
69 fuel line question - vapor return or not? Eric Kammerer Engine 7 Jun 11th, 05 07:08 PM
Help! Brake line routing question WaynesWorld Brakes, Suspension & Steering 6 Oct 10th, 04 05:24 AM
