Re: Valve cover gasket
This job would basically be duck soup if you wanted to do it yourself... Most motors manuals will tell you what to do .. Torqueing is a no brainer... just enuff to get some squish to your cork gaskets. Most rubber does not absorb enuff to seal properly.
TC # 349
