Need Help With Some Engine Codes - Team Camaro Tech
post #1 of 5 (permalink) Old Oct 18th, 05, 11:54 AM Thread Starter
Question Need Help With Some Engine Codes
FLYWHEEL 3791021
HEADS 3782461
SUFFIX CODE VO2O9ME
BACK OF BLOCK 3914678
ANY HELP WOULD BE GREAT THANK YOU. IM GETTING READY TO SELL ALL OF THIS SO I WANT TO GIVE THEM THE RIGHT INFORMATION
chris2343 is offline
post #2 of 5 (permalink) Old Oct 18th, 05, 12:54 PM
Guess
HwyStarJoe's Avatar
Re: Need Help With Some Engine Codes
Heads:
3782461....'64-'66...327ci......Camel hump,no accessory holes,160/62cc port volumes,62cc chamber
Suffix:
ME.... 1967.... 327.... Powerglide.... 210hp....2bbl....Camaro
Block:
3914678....302.....'68....2-bolt...Z-28 Camaro
3914678....327.....'68....2-bolt
3914678....350.....'68....2-bolt
HwyStarJoe is offline
post #3 of 5 (permalink) Old Oct 18th, 05, 01:06 PM Thread Starter
Thanks for your reply do know what size the valves are? and also the suffix code is the same motor as the back of the block code. does that make sense?
post #4 of 5 (permalink) Old Oct 18th, 05, 02:51 PM
Guess
HwyStarJoe's Avatar
I would imagine that it's a 1968 327 from a Camaro.
It confuses me as well. The gurus of knowledge will know for sure why the discrepency.
I'd only be guessing about valve sizes, from inexperience, but I'd imagine they're small 1.94/1.50.
post #5 of 5 (permalink) Old Oct 18th, 05, 05:53 PM
Smile Re: Need Help With Some Engine Codes
My big valve virgin chambered -461's cc'ed at 66.0 and 66.+ cc's! You can see and feel the factory big valve head plunge-cut too.
I figure the 62 cc stuff come's from 1.72"/1.50" valve -461's and the 64 cc from 1.94"/1.50" -461 heads...
pdq67
WHY KEEP ENGINE RPMS under 7000rpm grumpyvette Performance 50 Oct 4th, 05 10:39 AM
Engine codes bgreen63366 Tag Team 3 Aug 29th, 04 12:03 PM
Engine codes MAX77 Tag Team 2 Jan 6th, 04 07:02 AM
engine codes Craigs 68 Tag Team 2 Dec 14th, 01 11:05 AM
Cowl, Vin, and Engine codes on 1970 Camaro skidoorcng Tag Team 5 Jun 7th, 99 07:21 PM
