1967 camaro 396 engine - Team Camaro Tech
post #1 of 5 (permalink) Old Oct 18th, 05, 07:09 PM Thread Starter
red
Question 1967 camaro 396 engine
Wanting to no what engine casting numbers should be in a car with a build date of 7B , second week of July. It is a 4K car and I thought it should have the block casting of #3902406, and the heads of #3904391. A friend has a motor with casting numbers of #3916323 and heads of #3919840, and block date of F-15-7. Can anybody help with info about this, and how close the engine date to car build date is normal???
Charlie
red67L78 is offline
post #2 of 5 (permalink) Old Oct 19th, 05, 06:45 AM
Re: 1967 camaro 396 engine
Hello Charlie, Met you at carlisle this past summer. We talked about metallic brake rears. Here is what I have learned. There are late camaros and chevelles that have 323 blocks in them I know of two that were orig. and I also have an orig. 67 chevelle block that still has the vin on it. It was cast F87 and assembled 0626EG ( I may be off a day or so on the assy) And all these would have been 4bolt blocks. I've also talked to some guys that have 406 blocks into june but they seem to be 2bolt 325 horse blocks but that sure doesn't mean they didn't make 4bolts too . Maybe some one will chime in who has had one of those blocks . The block that I have had one F 7 7 840 and a replacment 291 . I think the 840 was orig. It seems that there are no 391s past april so I believe your car would have 840s being a very late car
green z is offline
post #3 of 5 (permalink) Old Oct 21st, 05, 08:34 PM Thread Starter
red
Still can't figure out that one rear end? The fill plug is smaller than the other ones?
Just got back from a 350 mile road trip. 7 miles from home my alternator started winning and my key switch started smoking up through speaker grill. I stopped car and unpluged alternater wire plug. Then started up and continued home , stopped car while it started smoking again., that wire smell, and reach up and burned my figures on back of key switch feeling for heat. Then looked under dash and was very small flame on plastic. ??? Have you had this before. ?? Got to go get car from friends house tomarrow. But from what you are saying it looks like this engine would be legal in my car?. Another question is , what about the exhaust manifold casting numbers ?
red67L78 is offline
post #4 of 5 (permalink) Old Oct 24th, 05, 07:54 AM
The books say 879 & 880 manifolds
green z is offline
post #5 of 5 (permalink) Old Oct 24th, 05, 12:50 PM Thread Starter
red
Thank you for your help. Well just took apart key switch and it was arking between the solnoid circuit . The key switch looks wore out in side and was to far to next postion inside.
red67L78 is offline
1967 Camaro 396 build date and vin cut in no. JOE58 Tag Team 13 Aug 22nd, 05 01:30 PM
Rear End Decode HELP 1967 RS-SS Camaro ibuyncr Tag Team 1 Jan 27th, 05 02:20 AM
77 Camaro needs engine, help! danhei Engine 18 Oct 18th, 03 03:46 PM
5th Gen Camaro in 07? 69ProTouring Bench Racing 6 Sep 16th, 03 12:24 AM
1967 camaro "black panther" z/27 camaro Performance 4 Sep 6th, 02 06:20 PM
