The last PCV question - Team Camaro Tech
post #1 of 2 (permalink) Old Oct 19th, 05, 06:23 AM Thread Starter
O.K. the vacume line that I am using....it goes from the large vacume fitting at the bottom of the carb, to the valve cover. And the other valve cover has a hose to the air cleaner.... right??
edcorsaro is offline
post #2 of 2 (permalink) Old Oct 19th, 05, 07:21 AM
Re: The last PCV question
Yes, there is a hose from the air cleaner to the elbow to the v/cover, on a stock 68-69 set-up.
PCV routing question edcorsaro Engine 6 Oct 18th, 05 09:48 PM
PCV Valve/Breather Question thorpe67RS Camaro Tech 6 Sep 21st, 05 05:57 PM
Air Cleaner PCV Hookup for 68 RS/SS SB Manual w/A.I.R aburgess Restoration Corner 0 Sep 8th, 05 06:12 PM
PCV location--front or rear of valve cover? Brentmc Engine 3 Jul 26th, 05 10:29 AM
69 fuel line question - vapor return or not? Eric Kammerer Engine 7 Jun 11th, 05 07:08 PM
