electronic fuel injection to carburated - Team Camaro Tech
post #1 of 6 (permalink) Old Oct 19th, 05, 09:35 AM Thread Starter
im doing an engine swap on my 1991 camaro RS and putting an 1991 IROC 350 carburated engine in. can anyone give me some advice on converting electronic fuel injection into carburated?
thanks...
tiggerkiller is offline
post #2 of 6 (permalink) Old Oct 19th, 05, 10:02 AM
Re: electronic fuel injection to carburated
Well, a lot of the electronics won't be used with the carb, especially if you go manual choke or no choke at all. One thing that might happen is that a "check engine" light or similar warning indicator may stay lit on the dash with the computer disconnected. For this, I would just pull the bulb. I guess ultimately, the engine won't need any of that EFI stuff once you go carb, but that might interfere with some emission laws depending on where you live, not sure. I live in Canada, so I know a lot of guys who just swap to a carb and toss the EFI, and don't need to worry about emissions. It may not be so cut and dry where you are.
BreathWeapon is offline
post #3 of 6 (permalink) Old Oct 19th, 05, 10:06 AM
you could just swap all the EFI stuff to the other block, and not worry about smog laws
400bird is offline
post #4 of 6 (permalink) Old Oct 21st, 05, 02:35 AM
Alex
Here is my advise. Don't do it! I would way rather have fuel injection. Unless the rs has a 6cyl?
dragsterman is offline
post #5 of 6 (permalink) Old Oct 21st, 05, 06:17 AM
all that...
B2l will run ok on carb but for a daily driver better to keep the EFI...
if it is a V6 remeber the trans bellhousing is much different...
if for a lack of options you must go carb... get a good fuel pressure regulator with a return for the pressure the stock fuel pump will provide... as well, you will need a distributor w/ mechanical and vacuum advance...
another thing to take note of...
VATs... the pass key system and figuring out how to get it all to work reliably or eliminating it from the integrated system... (this then without the ECM controls make it interesting to say the least... keep a bunch of reference matierial hady to include a conplete chassis wiring diagrasm...
68 camaro... your tipical hipo 350... stl crnk... h beam rods full floating pistons mild cam, auto trans (wanting 700r4)... gears 3.73's... smokes tires lots of fun... also 87 IROC 305TPI 5-speed
zroc is offline
post #6 of 6 (permalink) Old Oct 21st, 05, 07:42 AM
BonzoHansen's Avatar
thanks...
I do not think a 91 IROC came with a carb. So if it is, what is really in that engine, because I am guessing it is not original?
Also, emissions laws need to be considered.
TC Member #13
BonzoHansen is offline
Vortec Fuel Injection BrandonL Performance 0 May 24th, 05 09:43 AM
fuel injection gas tank and pump 67ragtp Performance 0 Jan 12th, 05 03:47 PM
Fuel injection problem Leviathan Engine 0 Sep 7th, 04 08:04 AM
Edelborck fuel injection system hendo5767 Performance 9 Nov 26th, 02 07:00 AM
Junkyard fuel injection???? Radio Joe Engine 1 Mar 28th, 01 06:13 PM
