How to Install New Exaust Sytem - Team Camaro Tech
post #1 of 5 (permalink) Old Oct 20th, 05, 12:31 AM Thread Starter
How complicated is it to replace the full exaust system in my '67. I'd be replacing it with a stock system. I've got the two long pipes, the muffler and the tailpipes. Looks like the stock system is just clamped together? Any welding required up near the exaust manifolds or just bolted or clamped together?
SFCamaro is offline
post #2 of 5 (permalink) Old Oct 20th, 05, 08:08 AM
Re: How to Install New Exaust Sytem
Factory type are all bolted and clamped. I did an American Thunder system on my 68 and it's all clamped with the threaded end towards the drive shaft (looks better), but would like to have welded it.
68 Camaro~LSx ~all motor
post #3 of 5 (permalink) Old Oct 20th, 05, 09:17 AM Thread Starter
Thanks. What do you mean by "threaded end"? Why would you have liked to have welded it?
SFCamaro is offline
post #4 of 5 (permalink) Old Oct 20th, 05, 10:54 AM
Welding gives less chance of leaks, but I wasn't sure about mine since its aluminized pipe. As for the threaded end, I was talking about the muffler clamps.
post #5 of 5 (permalink) Old Oct 20th, 05, 12:02 PM
with a factory style exhaust, the only likely trouble spot is where the pipes bolt onto the manifold, or more accurately, getting the old ones off. hose it down well, and over several days, with some good penetrating oil. Those nuts rust bad, and the studs rust too, and break easily. work em gently with an impact wrench to knock the rust loose, in and out kinda thing. A torch can help, too. heat em up, then squirt em, the use the wrench, repeat....
There'll be a heat riser valve on the pass side, and you'll need a flat gasket for that plus 2 donut gaskets for the pipes, plus 6 new brass nuts.
Global West Spacers--how to install? Brentmc Brakes, Suspension & Steering 2 Jul 23rd, 05 01:10 PM
2004r install 67 Plain Jane Transmission & Driveline 3 May 2nd, 05 10:10 AM
Hurst Competition Plus Install Problems w/Console MytMini Transmission & Driveline 13 Mar 23rd, 03 05:51 PM
Subframe connectors install question HwyStarJoe Body Shop 4 Jul 18th, 02 10:45 AM
1984 Camaro Exaust PHDeathAngel Tech 2000 4 Apr 16th, 01 10:27 AM
