rear main seal - Team Camaro Tech
post #1 of 4 (permalink) Old Oct 20th, 05, 10:07 PM Thread Starter
rear main seal
I have the trans pulled on my '89 RS/305. While it's out being overhauled I want to replace the 1-piece rear main seal. Can I just pry the seal out of the seal housing, or does the housing have to be removed too? I've heard conflicting info on this. If it can be removed as is, is there a special tool required, or will a screwdriver do? There are 3 slots in the housing around the seal, I'm hoping they're to pry the seal out.
DesertRS is offline
post #2 of 4 (permalink) Old Oct 21st, 05, 04:28 AM
Banned
Re: rear main seal
Those seals just pop out with a scew driver put some grease in the lip and drive the new seal in as that maybe tricky keeping it staight.
CNC BLOCKS N/E is offline
post #3 of 4 (permalink) Old Oct 21st, 05, 07:43 AM
Re: rear main seal
You may want to use a little bit of silicone, or some other type of sealer on the outside (metal body) of that seal before you drive it in. And as mentioned above, make sure you lubricate the lip of the seal where it contacts the crank to keep from burning it up (dry seal) on the next start up.
1969 383CI, T-56, 12 bolt-3.31 posi, 13" C5 Rotors, PBR Calipers, rear disc system..
Go69 is offline
post #4 of 4 (permalink) Old Oct 21st, 05, 06:28 PM
Talking Re: rear main seal
He, He!!
The old rope seals that you had to pull through using a "chinese handcuff" were fun!!
pdq67
Oil leak - main rear seal? Samuel Engine 4 Sep 19th, 04 06:07 AM
rear tranny seal motroman Transmission & Driveline 2 Jun 2nd, 04 04:35 AM
400 SB Rear Main Cap rogue68 Engine 3 Mar 28th, 04 07:07 PM
main seal question moonshine Tech 2000 5 Jun 7th, 01 06:23 AM
Rear main seal keeps going out in motor please someone HELP??? 98TJ Engine 4 Apr 19th, 01 04:52 PM
