Hp Estimate - Team Camaro Tech
post #1 of 10 (permalink) Old Oct 22nd, 05, 12:25 AM Thread Starter
Send a message via Yahoo to camaronut79
Hp Estimate
hey guys I was wondering if some one could give me an anwser on about how much hp im making ,and any advise on add ons its a 383 stroker
Hasting Moly Rings
Federal Mogul flattop Piston (forged)
Clevite Rod Brgs
Clevite Main Brgs
Clevite Cam Brgs
Melling or Sealed Power Hi volume Oil Pump
Crane Energizer Camshaft and Lifters lift @ .050 .450in .450exh dur .218 .218
Cloyes TRUE Roller Timing Components
scat forged 3.75 crank
scat forged I beam rods
chevy double hump heads stainless steel 2.02 1.6 valves
holley dual plane intake
edelbrock 650cfm carb
open headers
camaronut79 is offline
post #2 of 10 (permalink) Old Oct 22nd, 05, 01:32 AM
Send a message via AIM to RamAirDave
Re: Hp Estimate
My painter/partner was running a 383 stroker (350 block, stoker crank) in his 73Z.
Similar setup, but your's looks to be more mild than his. It was running a comp XE274 (~.490 lift, 230/236 duration @ .050, LS 110). Edelbrock Air Gap, 750 Demon, ported Dart heads, headers. Scat "cast steel forged" crank, whatever thats supposed to mean (and had to be drilled like crazy in order for it to balance). Im guessing cast, but havent gotten around to checking. Eagle h-beam rods.
Chassis dyno'd at 305 hp, and I think around 330 tq. Was running very rich, so I think theres was more left in it. With leaner jets (no dyno), it ran 13.1 in the 1/4.
In case youre wondering why I used the term "was"
Found in the oil pan:
Crank came apart in 4 places, at around 12-1500rpm. May be difficult to see from the pic, but each part of the back half of the crank came apart:
Im not saying 383 strokers or Scat cranks are bad, but we've obviously had our issues.
dave
Driving a #s-matching Z in the rain..... and lovin' it....
RamAirDave is offline
post #3 of 10 (permalink) Old Oct 22nd, 05, 01:57 AM Thread Starter
Re: Hp Estimate
wow i hope that dosnt happen to me I just now hit the 250mile mark on this new motor. for some reason to me it feels like i got more then 300 horses but I could be wrong.
post #4 of 10 (permalink) Old Oct 22nd, 05, 08:40 AM
Chris
Cool Re: Hp Estimate
I would guess about 375 - 400 HP.
Wow, that pic is some awesome carnage!
1967 Chevelle 496BB/TH400/Dana-60 (Show and Go)
1967 El Camino 388SB/700R4/12-bolt posi (Daily Driver)
1967 C10 Short-Wide 496BB/TH400/12-bolt (The Shop Truck)
2008 Harley Davidson Dyna Low Rider
Chris @
Motorhead62 is offline
post #5 of 10 (permalink) Old Oct 22nd, 05, 09:08 AM
Re: Hp Estimate
I would guess around 375. THe pic has quite a bit of destruction. Scary that it was at only 12-1500RPM. Imagine at 5500. WOW.
DirtyScotty is offline
post #6 of 10 (permalink) Old Oct 22nd, 05, 08:41 PM
Re: Hp Estimate
The 305 hp figure we got was at the rear wheels. Probably couldve tuned another 20hp out of it. And with a power-sapping 700R behind it, we figured it was probably in the low 400hp range at the crank.
I think the 375-400 range suggested above would be where youre at.
dave
post #7 of 10 (permalink) Old Oct 22nd, 05, 10:14 PM Thread Starter
Re: Hp Estimate
I also forgot its bored .060 over and i planned on shelling out the 300$ for a roller cam. if i can ever get my starter problem fixed. if you can check out my other post (starter or flywheel problem) I really need help in that department.
thanks
steve
post #8 of 10 (permalink) Old Oct 22nd, 05, 11:02 PM
Re: Hp Estimate
Making it into a roller motor will most likely add a good amount of hp. We're replacing the broken 383 engine with a 366 roller motor, actually.
Havent really looked at prices in a while, but I'm pretty sure its more than $300 to go roller. Its not just a cam swap. You also have to change the lifters and rocker arms. Possibly valve springs also, depending on the cam and the added amount of lift you usually get from rollers.
I just responded to your other thread. Hope it helps.
dave
post #9 of 10 (permalink) Old Oct 24th, 05, 05:30 AM Thread Starter
Re: Hp Estimate
o yeah I know it's more then 300$ it usually run's about 600-700$ but a friend of mine has a full roller set frome comp cams that he was going to put in his 355 before blew the motor now he's going big block and he said he would sell me the set for 300$ cash. would the fact that my motor is board 60 over add any to that 375-400 estimate?
post #10 of 10 (permalink) Old Oct 24th, 05, 06:29 AM
Craig
Re: Hp Estimate
I run a similar setup to what Daves friend is (was) running with my 383. Mine dynod at 415hp/450tq, at the crank. I see you are running a 650 cfm carb, think these motors run stronger with a 750. I have a 750 Holley DP on mine.
thorpe67RS is offline
1/4 Mile estimate please JaySB Performance 3 Oct 7th, 05 12:13 PM
Help with HP estimate? Rocketrod Engine 4 Sep 27th, 05 12:16 AM
Seat Covers & Foam Estimate stmay Interiors 8 Aug 2nd, 05 08:22 AM
Horsepower estimate 70chevyz28 Performance 2 Apr 15th, 04 07:22 AM
New Paint job estimate peters76 Body Shop 24 Dec 21st, 02 01:21 PM
