oil pressure - Team Camaro Tech
post #1 of 12 (permalink) Old Oct 22nd, 05, 05:10 AM Thread Starter
Steven
stamatisg1977's Avatar
oil pressure
hey people,
can anyone tell me what the ideal oil pressure is for a 350 small block at idle.
(800rpm) my guage is reading around 30-35psi. is this good? my father says its too low.
please help me settle this one
thanks
steven
stamatisg1977 is offline
post #2 of 12 (permalink) Old Oct 22nd, 05, 06:01 AM
Banned
Re: oil pressure
Originally Posted by stamatisg1977
hey people,
thanks
steven
That oil pressure is perfeact, The question is why would you need more at idle?????????????????????????????????????
CNC BLOCKS N/E is offline
post #3 of 12 (permalink) Old Oct 22nd, 05, 06:14 AM
Re: oil pressure
Rule of thumb, 10 psi for every 1000 rpm
TC # 349
zdld17 is offline
post #4 of 12 (permalink) Old Oct 22nd, 05, 07:03 AM Thread Starter
Steven
Re: oil pressure
thanks, i just won me 20 bucks!!!
post #5 of 12 (permalink) Old Oct 22nd, 05, 08:36 AM
Chris
Cool Re: oil pressure
Oil pressure should be at least 15 -20 PSI at idle, about 30 PSI at 1000 RPM and about 50 PSI at 2500 - 3000 RPM for a standard volumn oil pump. Your pressure is okay.
Keep in mind, differant types of oil can change your pressure also. Thicker oil adds pressure.
1967 Chevelle 496BB/TH400/Dana-60 (Show and Go)
1967 El Camino 388SB/700R4/12-bolt posi (Daily Driver)
1967 C10 Short-Wide 496BB/TH400/12-bolt (The Shop Truck)
2008 Harley Davidson Dyna Low Rider
Chris @
Motorhead62 is offline
post #6 of 12 (permalink) Old Oct 22nd, 05, 01:22 PM Thread Starter
Steven
Re: oil pressure
good i use mobil 1 synthetic 10w30
post #7 of 12 (permalink) Old Oct 22nd, 05, 02:21 PM
Banned
Re: oil pressure
The Nextel cup engines turn almost 10,000 RPM and run only 40 to 45 pouds of oil pressure what rule of thumb are they using.
post #8 of 12 (permalink) Old Oct 22nd, 05, 03:02 PM
Banned
Re: oil pressure
Since Mobil 1 has change there formular to meet the governments recomendations by lowering the zinc and phosphate its not recomende to be used in perfromance applications as these are the major friction reducers in oils.
Any of the 20/50 oils on the market today don't say RACING OIL on the bottles like they use to is because they have lowered the zinc and phospahte in the oil and its not a peformace oil any more.
The only oil today that is made in the U.S. and is considered to be used in racing engines is the old green Kendall which is marketed as Brad-Penn oil which is still made at the old Kendall refinery check out there website http://www.amref.com/
We use the Kendall to break our cams in on the dyno and from there on the circle track engines we have the go to the 20/50 Amsoil which is a RACING OIL with zero problems and the High performance steet engines we build we have them stay with the Brad-Penn and no issues.
We do some busssiness with a shop that did a lot of dyno testing for Mobil 1 and since the formular change they won't use it any more as they were having cam shaft and lifter failuars on flat tappet cams at the tracks, But when they were on the dyno and the cams were broke in and after doing all the dyno runs no problems with the Brad-Penn but the customers would go to the track with Mobil 1 and not even make the practice with out a failuar.
If any body wants the phone number of the shop with all the info. PM me as this shop owner has far more info on this matter then I have posted.
post #9 of 12 (permalink) Old Oct 22nd, 05, 05:13 PM
Re: oil pressure
The rule that says they can afford to rebuild their motors every 500 miles or so.
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
Mark C is offline
post #10 of 12 (permalink) Old Oct 22nd, 05, 08:12 PM Thread Starter
Steven
Re: oil pressure
but its a daily driver not a track car or race car
post #11 of 12 (permalink) Old Oct 22nd, 05, 08:29 PM
Banned
Re: oil pressure
GEE why don't you post that at the begining of your thread instead of the end.ITS DAM HARD TO BE A MIND READER!!!!!!!!!!!!!!!!!!!!!!
post #12 of 12 (permalink) Old Oct 22nd, 05, 09:04 PM Thread Starter
Steven
Re: oil pressure
sorry
Oil pressure? 67ragtp Performance 19 Oct 26th, 05 02:32 PM
Car wont start - smoke at air intake - No oil pressure wrath_of_con Troubleshooting 3 Oct 17th, 05 09:54 AM
New Engine, Low Oil Pressure? Cameron Engine 2 Sep 17th, 05 08:57 AM
Fresh 302 oil and oil pressure question Gary L Engine 7 Jun 17th, 05 04:22 PM
