MSD BLaster Coil leaking - Team Camaro Tech
post #1 of 6 (permalink) Old Oct 22nd, 05, 04:42 PM Thread Starter
Kevin
Question MSD BLaster Coil leaking
I noticed today that my MSD blaster coil was leaking oil. It has been laying on its side while I have been trying to get the motor timed. It hasn't been running very good and I suspect this may be the problem. I assume this is not a good thing, but I believe I have seen other cars with coils mounted sideway on their firewall? Is this a bad thing to mount the coils sideways or did I just get a bad coil?
67 Camaro rs/350 HO(est. 401hp)/4L80E/8.5" 10 bolt 3.73
Sixty-Seven rs is offline
post #2 of 6 (permalink) Old Oct 22nd, 05, 04:48 PM
Harry
dawg's Avatar
Re: MSD BLaster Coil leaking
coils should be mounted upright all the time.
you got cooling oil leaking out.
434 stroker
US Navy retired
dawg is offline
post #3 of 6 (permalink) Old Oct 22nd, 05, 04:49 PM Thread Starter
Kevin
Would this foul out the spark, so the engine would run very rough? Also, is the coil shot now? Or is it still usable?
post #4 of 6 (permalink) Old Oct 22nd, 05, 06:23 PM
Bill
67,
No matter how it is mounted, it should not leak. I have seen them mounted in almost every possible direction, right or not, but they still dont leak. However, the coil should be mounted upright according to MSD.
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
post #5 of 6 (permalink) Old Oct 22nd, 05, 06:38 PM
Leaking cooling oil,, oil keep it from overheating... Pitch it... Get a new one. Check the tag at the bottom of the new one,,, make sure its from USA.
Please note, some numbers of RED Blaster III's, p/n 8223, were made by Pro-Bobbin, will have a "Made in Mexico" sticker on their bottom. Don't use these coils. About a year ago, Blaster III production went back to where all Blassters used to be made, Andover, Indiana. Andover still makes, and has always made the CHROME Blaster II's, p/n 8200. The good Blasters will have a chrome sticker on their bottoms with "Made in USA" on them.
TC # 349
zdld17 is offline
post #6 of 6 (permalink) Old Oct 22nd, 05, 09:32 PM Thread Starter
Kevin
Thanks for the info guys. I really appreciate it. I will contact Summit and see if I can exchange it. This was part # 8200. Was looking at part #8223 until I read zdld17s post (thanks for the heads up).
KEvin
MSD and coil question flyers69 Performance 1 Jun 18th, 05 01:44 PM
MSD Blaster 2 coil hot wire. no bail4u Electrical & Wiring 2 Mar 10th, 03 10:21 AM
MSD Blaster 2 coil. '67 327 no bail4u Electrical & Wiring 3 Mar 3rd, 03 09:12 AM
MSD blaster 2 coil atldc Performance 2 Dec 22nd, 02 01:04 PM
Pertronix and MSD with High voltage coil ?? Joe Harrison Engine 1 Oct 17th, 01 07:22 PM
