Building a 427. - Team Camaro Tech
post #1 of 7 (permalink) Old Oct 23rd, 05, 08:55 PM Thread Starter
Building a 427.
There seems to be a lot of tech info here so thought I would pose a few ???.
1. 163 intake on oval port heads..anyone done it? results? opinions?
2. 2 bolt vs 4 bolt..4 bolt engines are always more $$ not building a numbers car, just a strong street car. also, how about adding 4 bolt caps to a 2 bolt block???
thanks team camaro
tom williams
we finally got a 69!!!
02 Berger 380hp 6spd red/white conv/Lots of L78 Novas.....69 SS350 Camaro..Karen's new addition!
WILMASBOYL78 is offline
post #2 of 7 (permalink) Old Oct 24th, 05, 09:15 AM
Re: Building a 427.
If it's a 4spd car and a Camaro I wouldn't use the 063 head. You don't need the mid range torque. I helped a friend build basically a stock L-72 with the 9.8 to 1 pistons and a Lunati cam. You don't need or can use anymore power than this thing has.
oger is offline
post #3 of 7 (permalink) Old Oct 25th, 05, 05:31 PM
Re: Building a 427.
I have been using 2-bolt main blocks for 30 years and never blown one yet. Biggest one was 454 with nitrous. Yeah, 4-bolt main blocks are probably stronger, but for 500 or so horsepower, 2-bolters work just fine.
Dave F. in Rhode Island
Chevy-SS is offline
post #4 of 7 (permalink) Old Oct 25th, 05, 06:18 PM
Bill
Re: Building a 427.
thanks team camaro
tom williams
Tom,
I'm going to ask the age-old question- what's your budget?
And what parts do you have/want to reuse?
WildBillyT is offline
post #5 of 7 (permalink) Old Oct 25th, 05, 07:53 PM Thread Starter
Re: Building a 427.
Trying to keep the budget in the $3000 range. would like to have a 427 cid engine. I have a set of 290 oval port heads that are in good shape. have a 163 intake, also have an Offy oval port intake(don't know if they are any good?) have a 72 402 2 bolt block..could sonic test and see how far we can punch it out. It has been hot tanked and magged..checked out ok. figure I will buy a good steel crank,(have the cast one from the 402..??)fresh set of rods and pistons/rings/bearings/ol pump. plan on using a Crane blueprint L78 solid cam, would spend some money on the heads: 2.19 & 1.88 valves, hardened seats, new guides, performance valve job, blending as needed for larger valves. have most of the other stuff: pan, timing chain cover, distributor, carb, etc.
post #6 of 7 (permalink) Old Oct 25th, 05, 08:07 PM
Re: Building a 427.
I don't think you would want to try boring the 402 block out to 4.250" (standard 427 bore size) but you might consider getting a 454 crank (4.00" stroke) to use in the 402 block. I know KB and maybe others make an off the shelf piston for this combo. It's sort of like the big block version of the 383 stroker, at a 4.155 bore (.030" over 402) you get 434 cu. in.
Blue69 is offline
post #7 of 7 (permalink) Old Oct 25th, 05, 08:26 PM Thread Starter
Re: Building a 427.
may also be able to swap the 402 block for a 454 motor..then I would be starting with the right bore size.
tom
building a 427( also posted in engine area) miked2004 Performance 22 May 21st, 03 03:03 AM
Building a 427 miked2004 Engine 1 May 15th, 03 06:28 AM
BIg Block Info I got off the web! Very long! pdq67 Performance 6 Jan 5th, 02 03:08 PM
Thinking about building a 427 69Man Performance 2 Aug 7th, 01 02:18 PM
Building a 427 engine Procharged69 Tech 2000 4 Jan 21st, 00 12:56 PM
