86 TPI intake MAF? - Team Camaro Tech
post #1 of 3 (permalink) Old Oct 24th, 05, 04:43 PM Thread Starter
86 TPI intake MAF?
Hey, I am stealing (i mean purchasing for $100 from a scrapyard) a TPI intake from an 86 IROC-Z, and placing it on a regular chevy SB 305. I was wondering, would a MAF from another camaro (V6) work on the SB TPI? or does it need to be THAT MAF? Also how hard is it to convert from MAF to speed density?
Racing_Master is offline
post #2 of 3 (permalink) Old Oct 24th, 05, 05:35 PM
Re: 86 TPI intake MAF?
Personally I would not convert from MAF to speed density. On SD systems, the ECM program is developed around the efficiency of the motor. If you change efficiency (heads, cam, exhaust), the program will have to be redone (or pay for a high $$ chip).
I doubt a V-6 MAF will work, but there should be plenty that will. It uses an analog MAF meaning it controls an analog voltage signal for the ECM to read. By comparison, some MAFs are frequency based meaning they change the frequency of a square wave for the ECM to read. Any voltage based MAF that is big enough for the motor and will plug in probably will work fine. They aren't cheap though if you buy new, and some autoparts stores won't exchange them.
dnult is offline
post #3 of 3 (permalink) Old Oct 24th, 05, 07:21 PM Thread Starter
So should I just scrounge around for GM MAFs in the scrapyard? and check if the plug fits? Shouldnt cost me anything, i could lie and say it was on the TPI :P
Lobe Separation Angle questions 69ProTouring Performance 19 Oct 10th, 05 06:41 PM
pro action (pro topline) intake gasket solution 68rs406 Performance 4 Aug 16th, 04 04:28 PM
Valve size info. pdq67 Engine 4 Mar 12th, 04 07:30 PM
Help with intake leak causing oil smoke 68SSConvt Troubleshooting 3 Jun 8th, 02 04:26 AM
Heat riser/crossover through the intake Sleepy-69 Engine 3 Nov 19th, 01 02:24 PM
