Valve seals - Team Camaro Tech
post #1 of 2 (permalink) Old Oct 24th, 05, 08:13 PM Thread Starter
"Tri-Tip"
Gary L's Avatar
Valve seals
What are the best seals for my DZ with high volume oil pump?
Gary L is offline
post #2 of 2 (permalink) Old Oct 24th, 05, 08:21 PM
Re: Valve seals
I don't think oil pump has anything to do with valve seals. Depends on whether you want to stay stock, use umberlla and stock or mill down bosses and use PC seals... either way you need them. Its the guides you have to deal with.
TC # 349
zdld17 is offline
Lobe Separation Angle questions 69ProTouring Performance 19 Oct 10th, 05 06:41 PM
Valve stem seals UPDATE Tire Smoke 69 Engine 7 Feb 15th, 04 02:15 AM
Replacing valve stem seals with heads on engine... Granny's 69 Engine 7 Dec 2nd, 03 09:03 AM
How to confirm smoke caused by valve seals? 68SSConvt Troubleshooting 9 May 29th, 02 06:30 AM
roller rockers Lil Greg Performance 9 Feb 12th, 01 04:26 AM
