oil sender questions? - Team Camaro Tech
post #1 of 5 (permalink) Old Oct 24th, 05, 10:22 PM Thread Starter
I was wondering if on a 68 camaro with a 327 is there any other spaces to mount the oil psi. sending unit into beside the back of the block by the dist.
my sending unit with my new gauge is to big and hits my intake so I cant thread it in.
badazzbowties is offline
post #2 of 5 (permalink) Old Oct 24th, 05, 11:04 PM
Steven
stamatisg1977's Avatar
Re: oil sender questions?
hello,
i had the same problem. and no there is no other spot to put the sender. i went to home depot and got some threaded pipe fittings and just extended the sender until it cleared the lip on the intake. you can also get a 90 degree fitting if the hight becomes an issue.
i hope this will help you. it works awesome i have had zero problems.
take care
steve
stamatisg1977 is offline
post #3 of 5 (permalink) Old Oct 25th, 05, 05:10 AM
You might try up front of the block, above the timing cover and below the intake manifold, on the pass side. There may be a 1/8 inch pipe plug.
This pipe plug is the front end of the main oil galley.
post #4 of 5 (permalink) Old Oct 25th, 05, 06:33 AM
Some blocks have a tap just above the oil filter , I think it was part of a external cooler package. This is not the same taps that the newer 350's have,, its more on the side of the filter than in front. Other than that you can do like one person mentioned. Get a short 1/8 nipple and plumb into 45 block bushing or if you have the manifold clearance,, use a 45 deg street ell. Surely you have enuff room to add the 1/8 nipple and collar. I think they make several differant pressure transducers. Remember the very small and short is a switch, the big can is a transducer.
TC # 349
zdld17 is offline
post #5 of 5 (permalink) Old Oct 26th, 05, 12:50 AM Thread Starter
hey thanks for the tips guys I found some fittings also at lowes that worked out for me so its all up and runnin now thanks alot.soon ill get pics of my custom dash now that its all done.
Oil pressure and type questions DirtyScotty Engine 3 Oct 8th, 05 09:05 AM
98 Blazer oil change questions Riccbhard Engine 5 Jun 24th, 05 10:55 AM
AutoMeter oil pressure sender ROBS6T8 Electrical & Wiring 3 Jun 2nd, 05 09:40 PM
Oil pressure sender location 69rag327 Engine 5 Apr 20th, 05 11:47 AM
