Fresh engine, used cam. A couple of questions - Team Camaro Tech
post #1 of 9 (permalink) Old Oct 25th, 05, 06:59 AM Thread Starter
Gary
69Z28's Avatar
Question Fresh engine, used cam. A couple of questions
Does a fresh rebuilt engine with an already broke in cam still have to go thru the same start up as it does with a brand new cam? You know, the 2000 rpm for 20 minutes deal.
On a fresh built to specs .030 over DZ engine..what is recommended for head gaskets? or complete gasket set. The block IS NOT decked if you need to know that.
06A 1969 Camaro Z28 X33D80 69 B 711 Black Stripes Console w/tach and gauges.
69Z28 is offline
post #2 of 9 (permalink) Old Oct 25th, 05, 08:14 AM
Chris
Cool Re: Fresh engine, used cam. A couple of questions
Why would you install a used cam/lifter set in a new engine? The camshaft/lifters are the fastest wearing parts in a SB Chevy engine.
So lets say you do install this stuff: The lifters need to go back on the same lobes they were mated to in the previous engine. You should not need to break in the cam as usual at 2000-2500 RPM for 20 minutes.
On SBC's with iron heads and stock blocks I like to use the stock replacement FelPro Perma Torque head gaskets. They work very well and are resonable in price. Do not use cheap gaskets.
Good Luck!
1967 Chevelle 496BB/TH400/Dana-60 (Show and Go)
1967 El Camino 388SB/700R4/12-bolt posi (Daily Driver)
1967 C10 Short-Wide 496BB/TH400/12-bolt (The Shop Truck)
2008 Harley Davidson Dyna Low Rider
Chris @
Motorhead62 is offline
post #3 of 9 (permalink) Old Oct 25th, 05, 11:14 AM
Smile Re: Fresh engine, used cam. A couple of questions
High performance stock engines used the cheap, .020" thick steel shim headgaskets for years so go figure.
And some engines even had two stacked on them to lower the CR. before they worried all that much about quench and our now poor gas!
pdq67
post #4 of 9 (permalink) Old Oct 25th, 05, 05:24 PM
If you're using new lifters on used cam, then you need break-in.
If you re-using the old lifters, then they BETTER be on the same lobes as before. As long as they are, then no break-in necessary. If they aren't in the same bores as before then you will probably ruin cam.
If it's a roller cam, then it makes no difference at all.
Dave F. in Rhode Island
Chevy-SS is offline
post #5 of 9 (permalink) Old Oct 25th, 05, 06:37 PM
"Tri-Tip"
Gary L's Avatar
Cam and lifters are only $100 for the Crane blueprint 30-30. Whay take a chance? Jerry MacNeish told me to use the GM .028 composition gasket sold in the GM performance catalogue. They are available in stock at most chevy dealers. I can provide the number if need be.
Gary L is offline
post #6 of 9 (permalink) Old Oct 25th, 05, 07:16 PM
Gary,, I sent you a pm but will not go thru,, says you got too many in your box that has not been cleared...
TC # 349
zdld17 is offline
post #7 of 9 (permalink) Old Oct 25th, 05, 08:42 PM
"Tri-Tip"
Gary L's Avatar
It's clear now. Thanks.
Gary L is offline
post #8 of 9 (permalink) Old Oct 26th, 05, 06:42 AM Thread Starter
Gary
69Z28's Avatar
Exclamation Re: Fresh engine, used cam. A couple of questions
The cam [30-30] and lifters are brand new, and just broke-in with approx. 500 miles. Is currently in a .030 350 built with all the external parts from my 302. Runs great with no problems. As soon as I can get my Z to pass Delaware emissions curb idle test my 302 is going in. And NO i haven't got it to pass yet.
I really don't think I'll be using CHEAP gaskets...which is the reason why I asked that question...what is recommended?
Gary L...do you know if I can get those gaskets in a complete gasket set from GM?
I know about the lifters having to go on the same lobes. I have installed used cam and lifters before with engines already broke-in with NO problems, but never a "fresh [broke-in]" cam and lifters in a fresh engine. That's why I asked that question.
Why would the cam get ruined if the lifters aren't going in the same bore?
69Z28 is offline
post #9 of 9 (permalink) Old Oct 26th, 05, 01:55 PM
"Tri-Tip"
Gary L's Avatar
I am not sure if they are available in a set. The cam lobes "mate" to a specific lifter during break-in time.
Gary L is offline
Learning from revamping blower engine Tokyo Torquer Performance 11 Jan 24th, 07 01:44 PM
pre-assembly engine prep questions aonghus Engine 15 Jul 19th, 05 12:04 AM
Cam selection help Planet Camaro Performance 33 Jun 24th, 05 06:45 PM
Couple quick brake questions... Silver69Camaro Brakes, Suspension & Steering 4 Jun 1st, 04 02:26 AM
New ENGINE Questions englemac Tech 2000 1 Oct 13th, 00 04:06 PM
