383 stroker - Team Camaro Tech
post #1 of 4 (permalink) Old Oct 26th, 05, 12:09 PM Thread Starter
383 stroker
so i bought a 383 stroker long block, i purchased edlebrock 700 cfm carb, edlebrock intake, shorty blockhugger headers, new highflow water pump, and im thinking of getting a serpentine pulley kit, but im not sure if theres much difference in performance with serpentine than v-belt, also could some give a ballpark on torque and hp for this setup, thanx
Living_Lengend is offline
post #2 of 4 (permalink) Old Oct 26th, 05, 12:24 PM
Royce
Re: 383 stroker
you need to give more detail if you want a decent estimate. We need to know the cam specs, type and size of the heads, which Edelbrock intake, since they are shorty headers I assume they are 1 5/8", correct? You won't see any performance difference with the different belt type.
Royce (NO XQSSS) Bradley
camaroman7d is offline
post #3 of 4 (permalink) Old Oct 26th, 05, 12:57 PM Thread Starter
Re: 383 stroker
ok, so the specs on the heads are 194 on the intake and 1 500 on the exhaust. the cam spec are 204 on the intake and 214 on the exhaust, as for the head type, how can i go about finding that out
post #4 of 4 (permalink) Old Oct 26th, 05, 01:18 PM
Royce
Re: 383 stroker
The specs you listed are valve sizes. As far as the heads you didn't say if they were aftermarket or stock type GM heads. From the valve sizes I assume they are stock heads. There is a casting number on the top of the head (under the valve cover) with that number you can look up the specs on the heads (chamber size, runner size, etc..) all these things have effect on power and powerband. The cam numbers you listed appear to be duration at .050 numbers, does not say what the lift of the cam is nor the LSA (lobe seperation angle). Judging by the numbers it is a pretty mild cam and should make a lot of torque down low, that along with the heads. I would expect a powerband from idle to about 4500-5000RPM with a lot of torque, good motor for towning, Should make a fun cruiser engine with the right gears.
383 stroker runs like crap mwgrantny Troubleshooting 14 Oct 26th, 05 06:38 PM
383 Stroker Zack Engine 7 Aug 30th, 05 05:54 PM
383 stroker vs. 350 no69x-44 Engine 3 Mar 26th, 04 06:11 PM
383 stroker... Prostreetcamaro1 Performance 13 Jun 20th, 03 07:50 AM
383 stroker or not? Dual or single pattern cam? charlesc Performance 6 Apr 28th, 00 10:33 PM
