rockers - Team Camaro Tech
post #1 of 4 (permalink) Old Oct 26th, 05, 05:25 PM Thread Starter
Steven
stamatisg1977's Avatar
rockers
hey, what are the advantages of roller rockers compared to regular ones?
i just completed a valve cover swap and noticed that my heads were reworked with new valves/springs/rockers from the previous owner.
thanks
steven
69 Frost Green Camaro
LS3 with TSP stage 3 cam
Tremec TKO 600
Ridetech rear 4-Link
Follow my journey here:
stamatisg1977 is offline
post #2 of 4 (permalink) Old Oct 26th, 05, 06:35 PM
"Tri-Tip"
Gary L's Avatar
Re: rockers
thanks
steven
Less valve train friction. The roller tips don't add lateral load to the guide, which means less friction. The full rollers have less friction rotating.
Gary L is offline
post #3 of 4 (permalink) Old Oct 26th, 05, 07:06 PM
Re: rockers
To me its STRENGTH first, and the advantages of less friction.
Got to love those roller springs and .700+ lift cams.
TexasPerfProd is offline
post #4 of 4 (permalink) Old Oct 27th, 05, 02:07 AM
Re: rockers
Your valve guides will see less wear with roller rockers too.
BlackoutSteve is offline
Roller Rockers for 396 Mister G Performance 2 Jul 2nd, 05 12:32 AM
Conv rockers & subframe connectors catalkir Body Shop 7 Aug 14th, 02 06:50 AM
Comp cams roller tip rockers - vs - Stock rockers Granny's 69 Performance 35 Jan 28th, 02 05:25 AM
Roller rockers and Valve covers?? Badcaiman Tech 2000 12 Jul 7th, 01 06:44 PM
roller rockers sound terrible! camaro-69ss Engine 9 Jun 11th, 01 11:52 AM
