441 heads - Team Camaro Tech
post #1 of 3 (permalink) Old Oct 26th, 05, 05:50 PM Thread Starter
441 heads
The 69 camaro i just bought has 441 heads just woundering what they are.the full noumber is 3832411.The engine casting # is 3970010.The noumber on the front of the block is T0919HO.Do not if it is orginal motor.
javent is offline
post #2 of 3 (permalink) Old Oct 26th, 05, 05:59 PM
Re: 441 heads
Sure that was 3932441
Here is a little info on these.
67-79 1.94/1.50 250hp & 255hp 76 CC Chambers
Here is your block
3970010 68 - 79 350 & 327 145hp-375hp 2&4-Bolt mains/Truck/Hi Perf
TexasPerfProd is offline
post #3 of 3 (permalink) Old Oct 26th, 05, 07:56 PM
Re: 441 heads
I got a little flow data for those stock heads,, at .400 lift they flow 194 & 127 cfm intake/ exhaust @ 28" water. At .500 lift they flow 201/146 respectively. Thats not too bad,, with in 72% of each other.
The 461 head flowed better and ported even better and thats with 2.02 / 1.60 valves. Just thought I would throw that in .
TC # 349
zdld17 is offline
Question about heads?? Zack67 Engine 6 Apr 24th, 03 04:08 PM
Pro Action Heads my69gofast Performance 25 Feb 22nd, 03 08:33 AM
Small block heads MoeSS396 Performance 12 Nov 29th, 01 04:13 AM
Tell me if this is true about the sportsman 2 heads ? camaro79tx Engine 12 Nov 21st, 01 03:03 PM
truck heads vs. hump heads toolman Tech 2000 3 Nov 1st, 00 09:34 PM
