First Gen V8 Swap... Oil Pan? - Team Camaro Tech
post #1 of 3 (permalink) Old Oct 26th, 05, 09:23 PM Thread Starter
I have a good donor engine for my 69 Camaro. It is complete and out of a 1980 1/2 ton pick up 2 wheel drive. Will the oil pan work or will I have to buy a pan for first gen camaro?
69CamaroChic is offline
post #2 of 3 (permalink) Old Oct 27th, 05, 06:24 AM
Re: First Gen V8 Swap... Oil Pan?
Shanna -
If the pan on that truck engine is the original, it should be fine. GM didn't really change the small block pans that much on the light duty engines over the years.
A pan for a Camaro probably wouldn't work anyway, because of the dipstick location. The Camaro pan would be for a driver side stick, and I think a 1980 motor might have the stick on the passenger side.
Eric
Eric Kammerer is offline
post #3 of 3 (permalink) Old Oct 27th, 05, 07:13 AM
As Eric suggested, it will work as long as it is a rear sump pan, which it is.
350 oil pan VintageAgain Engine 5 Sep 20th, 05 10:54 PM
Stock oil pan for 383 1FASTZ Engine 7 Jul 25th, 05 05:33 PM
Help me choose new oil pan rcatala Performance 3 May 31st, 05 05:12 PM
Oil pan oil leak 68C Engine 5 Apr 16th, 05 11:23 AM
