fuel tank or gauge problem? - Team Camaro Tech
post #1 of 4 (permalink) Old Oct 27th, 05, 07:28 PM Thread Starter
I have something strange when filling up lately. When I fill it up when it hits 3/4 full on the gauge it takes around 7.5 gallons each time. I thought the tank is 18 gallon capacity. If so, wouldn't that mean around 4.5 gallons per 1/4 on the fuel gauge. Wondering if the tank needs replacing or is the new autometer fuel gauge not accurate?
norcalcamaro is offline
post #2 of 4 (permalink) Old Oct 27th, 05, 07:44 PM
Steven
stamatisg1977's Avatar
Re: fuel tank or gauge problem?
how old is the fuel sender?
after a long period of time the sender can go bad and give incorrect readings
69 Frost Green Camaro
LS3 with TSP stage 3 cam
Tremec TKO 600
Ridetech rear 4-Link
Follow my journey here:
stamatisg1977 is offline
post #3 of 4 (permalink) Old Oct 28th, 05, 08:44 AM
Christropher
Put a multitestor on the gauge. At 0 Ohms it should read empty, at 90 Ohms it should read full.
Christropher
...in pieces still.
clwilcox33 is offline
post #4 of 4 (permalink) Old Oct 28th, 05, 10:09 AM Thread Starter
Thanks I'll check it out when I get to half & see if the ohms are around 45-50. I suppose at 3/4 it shoud read around 65 ohms? It sdoes seem if it takes 7 gallons when i use 1/4 a tank of gas then I would run out before the gauge hits E.
Another Fuel Gauge Problem dnawags Electrical & Wiring 8 Dec 13th, 05 05:56 PM
Sugar in the gass tank, from snopes.com Joe Harrison Bench Racing 14 Sep 25th, 04 10:26 AM
fuel tank removal '67 Camaro Please need a hint or 2 cavemanmoron Tech 2002 12 May 14th, 02 03:31 PM
Fuel Gauge Bouncing tjgerow Troubleshooting 5 May 3rd, 02 03:13 PM
Help with my fuel gauge SSuperman Troubleshooting 2 Sep 20th, 01 06:25 PM
