Where To Find Aluminum Serpentine Pulleys? - Team Camaro Tech
post #1 of 8 (permalink) Old Oct 28th, 05, 10:59 AM Thread Starter
I was wondering if anyone had any good leads on aluminum (polished?) pulleys for a SBC, with long water pump, with serpentine conversion. I am using a '95 GMC pick up set up. I found the March site, was hoping to spend less than $300 on these items. If anyone has a good lead, please let me know.
I am looking for a crank, water pump, and alternator pulley if that helps.
1969 383CI, T-56, 12 bolt-3.31 posi, 13" C5 Rotors, PBR Calipers, rear disc system..
Go69 is offline
post #2 of 8 (permalink) Old Oct 28th, 05, 11:29 AM
Harry
dawg's Avatar
Thumbs up Re: Where To Find Aluminum Serpentine Pulleys?
try here:
http://www.blackmountainprecision.com/sb5.htm
cog system is better too!
i use the 2" setup on my camaro.
pic here;
http://webpages.charter.net/harrycoon/000_0003 (Medium).jpg
looks bitchin too
434 stroker
US Navy retired
dawg is offline
post #3 of 8 (permalink) Old Oct 28th, 05, 01:12 PM Thread Starter
Those cogged pullies are very nice. The only drawback I see is that they won't allow me to run my power steering pump which is also serpentine. If I later put on A/C, same dilemma as the p/s...
Neat pullies, but a little more exotic than I am needing.
If anyone else has any other ideas, I'm still hunting. I did find the March sets at $225 which I guess I can hold out on as a last resort. I found some really inexpensive sets for short water pump applications-less than $100 even with shipping. But not much in the way of long water pump.
Go69 is offline
post #4 of 8 (permalink) Old Oct 28th, 05, 01:47 PM
Christropher
http://www.conceptonepulleys.com/bigbasic.htm
http://www.marchperf.com/
http://zoops.com/home.asp
Most systems are available at Summit or Jegs. You can use ribbed systems with accessories like P/S and AC.
Also read this thread:
https://www.camaros.net/cgi-bin/forum...9;t=013368;p=0
Good luck.
Christropher
...in pieces still.
clwilcox33 is offline
post #5 of 8 (permalink) Old Oct 30th, 05, 08:32 AM
Harry
dawg's Avatar
they have the adapters for running the PS pump on those cog pullies btw.
434 stroker
US Navy retired
dawg is offline
post #6 of 8 (permalink) Old Nov 1st, 05, 12:08 PM
I'm with ya... I'm planning on installing a 350 vortec out of a 98 truck and I can't seem to find any way to make the stock serpentine setup look good.
Thanks for the links, maybe I'll find something I can work with!
68 Camaro Roller | 68 Camaro (#matching) | 69 Camaro
KWIK 69 is offline
post #7 of 8 (permalink) Old Nov 2nd, 05, 11:29 AM
take a look at jegs.com they have all kinds of combinations and finishes.
Ride13 is offline
post #8 of 8 (permalink) Old Nov 3rd, 05, 05:41 AM
Ckech out the Summit or Trans-Dapt brands - not as perfectly polished, but cheaper than March or Zoops. Type in "Aluminum Pulleys" in the search field.
http://store.summitracing.com/
jm69ss is offline
Cant find owner to 67 vert blue ss Bench Racing 0 Jul 26th, 05 08:17 AM
Engine pulleys will not line up LukeSkywalker Engine 12 Jan 2nd, 04 08:48 AM
Performance Pulleys? CamaroJSU Performance 2 May 10th, 03 05:22 AM
Cog Belt Pulleys? [RyanB] Tech 2002 1 Jul 19th, 02 10:09 AM
serpentine pulleys MY FIRST 69 Tech 2000 6 Aug 13th, 01 09:17 AM
