cam for 383 - Team Camaro Tech
post #1 of 19 (permalink) Old Oct 28th, 05, 09:27 PM Thread Starter
cam for 383
im building a 383 that is for a hot daily driver, the parts are, tfs 195 heads performer rpm air gap intake, 750 holley, 10.3 comp, eagle crank. i am going to use 1.6 roller rockers. the tranny is a 700r with 2800 stall and 3:73s. i need advice on what hydraulic flat tappet cam to use, i want around 230 duration+-. a flywheel horsepower estimate would be appreciated, thanks for the help.
69pacecar is offline
post #2 of 19 (permalink) Old Oct 29th, 05, 02:30 AM
Banned
Re: cam for 383
Give me a call a I can set you up with the same cam I used in this engine check this link out.
http://www.chevelles.com/forums/showthread.php?t=106715
CNC BLOCKS N/E is offline
post #3 of 19 (permalink) Old Oct 29th, 05, 07:06 AM
Re: cam for 383
hehe... I "hate" "secret cams" with unreal torque curves.... I also want one!
post #4 of 19 (permalink) Old Oct 29th, 05, 08:40 AM
Re: cam for 383
CNC. Would you be able to forward that cam my way also as I am in need of a flat tappet cam also and that torque curve looks mightly juicey.
DirtyScotty is offline
post #5 of 19 (permalink) Old Oct 29th, 05, 09:38 AM
Banned
Re: cam for 383
I will PM you the specs when I get the cam card from the engine shop.
post #6 of 19 (permalink) Old Oct 29th, 05, 11:10 AM
Re: cam for 383
Thanks. Looking forward to it.
post #7 of 19 (permalink) Old Oct 31st, 05, 04:45 AM
Re: cam for 383
Peak HP 455 @ 5400 RPM
TQ range was huge:422 ft lbs @ 2900 RPM and 437 ft lbs @ 5400 RPM, peak 501 ft lbs @ 4200 RPM.
Anybody see any problems with this?
Yeah, I should increase my "tire stock" shares !!!
As others, I'll be waiting for cam specs.
post #8 of 19 (permalink) Old Nov 1st, 05, 05:15 AM
Re: cam for 383
i"d like to see those specs also!
thank's in advance!
Eric B
86 camaro,383,topline vortecs,scat crank,wiseco forged 9.5:1,6"scat rods,comp xs282s,performer rpm,750 proform vac sec,msd in cap, hooker coated 1 5/8"headers,3"flowmaster,700r4,2800 stall,3.42 10 bolt posi,hotchkiss lca's,aje tube k member & a-arms
SLEEPER 86 is offline
post #9 of 19 (permalink) Old Nov 1st, 05, 02:03 PM
Wes
Re: cam for 383
I like your idea,..230 duraiton. Comp's Magnum 230H works great with 3.73 gears and at least 10:1 compression. Good quiet cam, fairly smooth (it'll idle at 900), doesn't do much to 2500 but after that, hang on!
My opinion.
Straight-line-69 is offline
post #10 of 19 (permalink) Old Nov 1st, 05, 03:06 PM Thread Starter
Re: cam for 383
what about the comp xe274h 230in, 236ex @.50,490in, 490ex would it be big enough for 400 hp with my combo?
post #11 of 19 (permalink) Old Nov 1st, 05, 05:03 PM
Re: cam for 383
Definitely. I just had that cam in a similar 383. Over 400 at the crank for sure. I loved the way the car drove as I will use mine on the street alot. Still have to pull the cam out of the car and look to see if the cam, lifter or valve spring pressure caused the ticking problem I had. I loved it though while it was alive. My combo has 9.7-1 comp ratio, procomp 200cc heads with 64cc chambers and Ferrea 2.02 1.60 valves and Victor jr intake with 750 vac secondary Holley.
post #12 of 19 (permalink) Old Nov 1st, 05, 05:55 PM
Re: cam for 383
Just beware of clearance issues. When you start to approach 0.500" lift (at the valve), you may have problems with the rods hitting the cam. Small base circle cams are often used to prevent some of the clearance issues, but I'll leave it to the experts here if a SBC cam is good to use with flat tappets or not. In my friends case, he ended up use an H-beam rod to get around clearance issues.
dnult is offline
post #13 of 19 (permalink) Old Nov 1st, 05, 08:28 PM
Harley D
HarleyD67's Avatar
Re: cam for 383
Take a good look at that Comp. Extreme cam XE274H. I had one in my 350. Reworked early 64cc stock heads, 9.6-1 compression 2500 stall 3.73's. Even "LOVED IT" great power and torque. good lopy idle. would be a little mellow in 383. even pulled 12.5" vacuum at idle.
HarleyD67 is offline
post #14 of 19 (permalink) Old Nov 1st, 05, 08:50 PM
Chris
Cool Re: cam for 383
Here is one for ya! I have 525 miles on my new 383 in my El Camino. I used an XE 264 hyd roller (212/218 duration and .487/.495 lift). I have 9.7-1 cr, 192cc SuperFlow alluminum heads that I ported, Air-Gap RPM intake, HEI, and 1 5/8 Hedman Elite headers.
This combo is very powerful yet mild mannered. It pulls very hard to about 5700 RPM and has a cool idle. This a daily driver for me and is backed up by a 700R4.
1967 Chevelle 496BB/TH400/Dana-60 (Show and Go)
1967 El Camino 388SB/700R4/12-bolt posi (Daily Driver)
1967 C10 Short-Wide 496BB/TH400/12-bolt (The Shop Truck)
2008 Harley Davidson Dyna Low Rider
Chris @
Motorhead62 is offline
post #15 of 19 (permalink) Old Nov 2nd, 05, 02:29 AM
Alex
Re: cam for 383
I would run a 292 Magnum comp cam. But for you wanting a more mellow can. Run a 280 Magnum. It will run good and have a lope too. That motor will easily handle a 292 though with the comp, ci and head.
dragsterman is offline
"setting" cam end play nitrous383 Engine 21 May 13th, 05 07:07 AM
Dialing in a Cam Silver69Camaro Performance 5 Dec 20th, 04 06:33 AM
sbc cam lsa question 396rs/ss Engine 12 Feb 13th, 04 03:40 PM
Help needed IDing LT1 roller cam Jeff H Engine 0 Jan 26th, 04 08:13 AM
How do I determine specs on used roller cam? Go69 Tech 2002 4 Sep 17th, 02 01:04 PM
