Big block mounting alignment questions - Team Camaro Tech
post #1 of 12 (permalink) Old Oct 29th, 05, 08:13 AM Thread Starter
I'm rebuilding the 454 in my '68 SS. This car was originally 350 equipped. I had the running 454 in there before and I noticed (when assembling) that the tranny crossmember would not line up. I had to pry the trans over to bolt up the trans mount to the crossmember.
So, now I have my engine at the shop and am using a spare 454 block and tranny case to check the fit of the engine and get things aligned correctly. If you look at the pic, I have drawn a white line in the approximate center of the chassis. The engine is clearly offset to the passenger side by about 3/4". Is this correct?
I AM using the correct BB frame mounts, and I'm using interlocking '69 style engine mounts. How does the driveshaft end up perfectly straight to the crankshaft? If not, it seems like it would cause vibration.
There may already be a good thread talking about this. I've been searching and can't find any that specifically talk about this. If there is, and someone could post a link, that would be great.
thanks
Dave F. in Rhode Island
Chevy-SS is offline
post #2 of 12 (permalink) Old Oct 29th, 05, 08:42 AM
Re: Big block mounting alignment questions
You need a big block crossmember. The mounting holes are offset.
69cama is offline
post #3 of 12 (permalink) Old Oct 29th, 05, 08:48 AM
Thumbs up Re: Big block mounting alignment questions
OR just use a three hole poly tranny mount and install the needed Grade-8 bolt and washers in the center hole through the pass. crossmember hole AND you will be fine.
That's how I have mine.
pdq67
post #4 of 12 (permalink) Old Oct 29th, 05, 08:55 AM Thread Starter
Thanks for replies.
But if I do what you guys suggest, won't the pinion angle be off a little sideways?
Chevy-SS is offline
post #5 of 12 (permalink) Old Oct 29th, 05, 09:03 AM
Yes, it will but as long as the engine is aligned to the center of the car you won't have any issues. Thats why there are big block crossmembers to match the offset of the big block motor mounts.
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
Mark C is offline
post #6 of 12 (permalink) Old Oct 29th, 05, 10:18 AM Thread Starter
Thanks for tips. I never really paid attention to the difference, but it's clear in this pic from Rick's First Generation that the big block crossmember is offset.
I had actually ground a little offset into the frame mount holes. I moved the driver-side mount 1/8" forward and the passenger-side frame mount 1/8" back. This got the tranny mount lined up perfectly with the small-block crossmember. Can I use this method, or is it really necessary to get the offset in the crossmember itself?
It seems like no matter which way you do it, the pinion angles will always be slightly off sideways.
Chevy-SS is offline
post #7 of 12 (permalink) Old Oct 29th, 05, 10:42 AM
for the ujoints to work as designed, the 2 things the driveshaft connects have to be parallel. That is, the engine/trans centerline and the pinion gear centerline. The u-joint angles must be "equal but opposite" So, no, you shouldn't run it the way you have it. The trans mount must offset the same as the engine mounts are. The engine will be off-center, but still be parallel to the car's (and the pinoin's) centerline.
post #8 of 12 (permalink) Old Oct 29th, 05, 11:21 AM Thread Starter
Originally Posted by JimM
for the ujoints to work as designed, the 2 things the driveshaft connects have to be parallel. That is, the engine/trans centerline and the pinion gear centerline. The u-joint angles must be "equal but opposite" .....
Yes, yes, very good explanation. Makes perfect sense. I will get new crossmember, or grind old one, or do as pdq67 suggests and use one grade 8 bolt in center hole of poly mount, since I already have a poly mount..
Thanks for help gents
Chevy-SS is offline
post #9 of 12 (permalink) Old Oct 29th, 05, 03:24 PM
Back again,
I think that you will find out that a BB will sit fine like I said b/c the center hole put's the tail-end over the needed about 1" towards the pass. side.
And the reason for the three holes in the first place is b/c the newer cars only use one rear mount bolt!
pdq67
post #10 of 12 (permalink) Old Oct 30th, 05, 06:27 AM Thread Starter
pdq67
Check out this pic:
Was your poly mount taller than the stocker? Do you (or anyone here) happen to know which height is correct?
thanks
Chevy-SS is offline
post #11 of 12 (permalink) Old Oct 30th, 05, 07:47 AM
Smile Re: Big block mounting alignment questions
I don't think so.
Mine fit fine.
Anybody else want to add anything that I may be missing?
pdq67
post #12 of 12 (permalink) Old Oct 30th, 05, 08:27 AM Thread Starter
Originally Posted by pdq67
Back again,
Perfect fit! After I put frame mounts back to stock position, the center hole of poly mount lined right up to passenger side hole in crossmember.
Now my only quandary is the poly trany mount maybe being too tall.
thanks again
Chevy-SS is offline
Any chance a 650 CFM Holley spreadbore will feed my big block?? Eric Kammerer Performance 9 Aug 5th, 05 08:45 PM
69 big block rear springs TOM BARKLEY Brakes, Suspension & Steering 5 Jul 31st, 05 04:26 AM
496 Big Block Chevy Upgrade ItDoRun Engine 4 Jul 22nd, 05 04:44 PM
67 big block fan 988280 Heating & Cooling 4 Jul 3rd, 05 04:33 AM
Big Block Front Springs jamesriediger Brakes, Suspension & Steering 6 Jun 12th, 05 12:13 AM
