85 V6 to V8 Swap - Team Camaro Tech
post #1 of 6 (permalink) Old Oct 29th, 05, 08:49 AM Thread Starter
85 V6 to V8 Swap
Hi folks,
please help, I only have a small one, engine that is.
I live in edinburgh Scotland and last year got my hands on a 85 2.8 mpi V6 with 3 speed + overdrive auto box. I believe the box is a 200 R4, so I was told anyway.
I have now decided I want more power, so naturally its time for a V8. I have spent a lot of time and money on the body of the car so dont want to just go out and buy another car, so the engine swap will have to be made.
What I need to know is, will I need to change my box, diff, breaks and suspension for V8 parts. I have been told that the V8's and V6's used a lot of the same parts?
Please help, winters setting in and its time to start building a new improved toy for summer.
Cheers
Chris
chris85 is offline
post #2 of 6 (permalink) Old Oct 30th, 05, 09:06 AM
Smile Re: 85 V6 to V8 Swap
I don't think your tranny will fit a V-8 b/c that engine is a 60 degree vs a standard 90 degree "V" motor?
As for everything else.
Probably a new bigger rad., V-8 front springs.....
Sorry, I am not that familiar with the newer year cars so can't help much..
Please go over to the "SGCOG" site and ask the guys there.
Good luck with upgrading your car..
pdq67
"Second Generation camaro Owners Group"..............
post #3 of 6 (permalink) Old Oct 30th, 05, 07:28 PM
what you will need, as pdq67 said, is a bigger rad because the V-8 is adequately larger than the V-6 therefore....more cooling is needed. As for the diff, you should be able to use your existing rear end. Your car came with the 3.42 gearing, no V-8 third gens came with these gears so i wouldnt know a whole lot about them. A cheap alternative is to get a 3.73 or 3.55 set. Anyways, you should also be able to keep the front shocks, but upgrading to a set of V-8 ones would be a better option. If you have the 3 spd overdrive, you are running a 200R4, and correct me if im wrong, swapping to a TH350 trans with a 6" tailshaft housing you should be able to use your existing driveshaft, not sure on the splines though As for your brakes to my knowledge the barkes on all third gens were the same. As for most parts on all third gens being the same, you are basically right, most parts are the same. I hope i cleared up a few of your quaestions, and good luck with the swap. Cheers
~~Nick~~
1PimpinZ28 is offline
post #4 of 6 (permalink) Old Oct 30th, 05, 08:33 PM
what about all the wiring, the efi, ignition, ecu? i doubt any of this would be the same from V6 to V8
400bird is offline
post #5 of 6 (permalink) Old Oct 30th, 05, 08:39 PM
Good point bird. All of your wiring and ignition has to be transferred from the donor car......if you are planning on using an donor car and not a crate motor. It would be much easier to have a donor car than have a V-8 crate motor. Also your motor mounts need to be swapped, and tranny crossmember (depending on what type of tranny you plan to use)
post #6 of 6 (permalink) Old Oct 30th, 05, 09:22 PM
We did this once back in the early 90's and it was kind of a pain. One thing to remember, is that your car has rear coil springs, so there is a torsion bar that runs from the rear axle to the tailshaft of the tranny you have now, so swapping directly to a 350 won't work very easily beacuse its tailshaft wont have the mounts for the torsion bar. After all was said and done, even though we went carbureted, it was more trouble than what it was worth. I am guessing there are no IROC's where you live? In the States, at least, you'd be better off selling and buying an IROC. Whatever you decide, best of luck.
67coupe is offline
305 to 350 Engine swap? SquareRoot Performance 11 Dec 5th, 05 02:58 PM
LT1 Swap? 1PimpinZ28 Camaro Tech 1 Jul 16th, 05 12:45 AM
LS1 Swap 1PimpinZ28 Camaro Tech 6 Jun 24th, 05 12:11 AM
Another Question For Those With The 200R-4 Swap bigdawginva Transmission & Driveline 17 Mar 31st, 05 02:20 PM
LS1 T56 Swap rmadsen55 Transmission & Driveline 2 Mar 28th, 05 06:29 PM
