bad lifter? - Team Camaro Tech
post #1 of 2 (permalink) Old Oct 31st, 05, 12:30 PM Thread Starter
Send a message via AIM to 67camaro02
bad lifter?
this problem started about a week ago. Whenever i start the motor up when its cold the car makes a weird noise from the motor and it runs really rough. This usually only lasted for about 10 seconds or so then it would go away and run smooth.
Well when i started it up yesterday the noise didnt go away for like 2 minutes or so then on the way to work it just started doing it constantly. I pulled the valve cover off and the rocker arm was completely off the pushrod and spring. The not on the stud didnt not come loose either. Does this sound like a lifter to you? What else should i check? thanks
67camaro02 is offline
post #2 of 2 (permalink) Old Oct 31st, 05, 05:01 PM
Re: bad lifter?
CHeck the cam also. I just pulled my lifters out and found one damaged. The lobes wear mark looks funny also compared to the rest.
DirtyScotty is offline
Bad lifter or bad camshaft? DirtyScotty Engine 11 Oct 30th, 05 05:36 AM
Bad window switch or bad motor Meanchicken Electrical & Wiring 2 Oct 3rd, 05 06:41 AM
Setting Pushrod Length - Solid/Hydrolic lifter JHunter Performance 2 Aug 2nd, 05 10:19 PM
Rhodes hydraulic lifters jlighthart Engine 13 Feb 23rd, 03 03:45 PM
roller rockers Lil Greg Performance 9 Feb 12th, 01 04:26 AM
